× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Can not change admin password on ReadyNAS Ultra 2 Plus
key5000
Hello,
I am having problem with changing password for my ReadyNAS Ultra 2 Plus, here is what I did:
1- go to Security\Admin Password then input new admin password and retype admin password
2- Reboot NAS but unable to login with new password but I am able to login with old password.
I'm running latest firmware 4.2.27
Please help.
Message 1 of 19
Nhellie
Virtuoso
Re: Can not change admin password on ReadyNAS Ultra 2 Plus
Did you click on "Apply" on the very bottom of the page?
Message 2 of 19
key5000
Yes, I did click on "Apply" and the message pop up saying the password change successfully. Reboot the NAS but unable to login with new password but OK with old password
Message 3 of 19
Nhellie
Virtuoso
Try performing an OS reinstall to reset the password back to default, once you can login on the default password -change it to the new one.
http://kb.netgear.com/app/answers/detail/a_id/21100
Message 4 of 19
key5000
For example, my old password to login to RAIDiator is "12345"
to change this password I'm going to Security\Admin Password and change it to "abcdef", click on "Apply" and reboot the NAS. See picture with link below.
https://onedrive.live.com/?cid=D8EAEF2B79FEEFFC&id=d8eaef2b79feeffc%216576&v=3
When I try to login to RAIDiator after the reboot, the new password "abcdef" does not accept it but when using the old password "12345" then I can login OK.
Another funny thing is when trying to access the file sharing using "\\192.168.1.xxx\" with admin login ID and password, it only accept the new password which is "12345", is that weird?
Please help me to solve this issue.
Thanks
KEY
Message 5 of 19
mdgm-ntgr
NETGEAR Employee Retired
Have you tried the OS Re-install Nhellie suggested?
Message 6 of 19
key5000
Will OS Re-Install erase all my files or my configuration?
Message 7 of 19
mdgm-ntgr
Your data will remain intact. Some configuration will be reset e.g. your admin password and some network settings.
Message 8 of 19
key5000
I did OS reinstall twice (power off, press reset button until all LED lit up, release the reset, select LED 2 and press reset button again and wait until it boot up again).
According to the manual, I should be able to login with the default password (admin, admin) but I can't. I can only login with my existing password.
When I changed the admin password under "Security\Admin Password", reboot the NAS but can't login with the new password. Again, I only able to login with my existing password.
Help, help.
Message 9 of 19
Guru
The default admin password on the ultra 2 is "netgear1", not "admin".
The procedure for the OS reinstall is on page 13 here: http://www.readynas.com/download/docume ... pril11.pdf. The last step is "press and release" the reset button, not "press it until the system reboots". I'm not sure you did hold the button down (your previous post could be read either way) - but wanted to mention it.
Message 10 of 19
key5000
Yes, I did try netgear1 too but the point is I am able to login to with my old password, some how it does not reset to the default even I try to reinstall the OS twice.
Message 11 of 19
Guru
Which is why I asked the press-and-release question.
The net here is that the OS reinstall procedure didn't succeed for whatever reason.
It's possible that the OS partition is full (not the data volume). That can create a bunch of weird symptoms, and eventually leads to lock-up.
Do you happen to have ssh enabled?
BTW, I recommend making (or updating) your backup w/o delay.
Message 12 of 19
mdgm-ntgr
Please check your PM inbox
Message 13 of 19
key5000
Hello mdgm,
Please check your PM.
Message 14 of 19
key5000
Hello Mdgm,
Please check your PM inbox.
Message 15 of 19
key5000
Hello mdgm,
Please check your PM in box.
Team viewer is good.
I am at home and available now for another 3 hours.
Let me know when you can so I can email you my Teamviewer ID
Thanks
Key
Message 16 of 19
mdgm-ntgr
Just had a 40 minute Teamviewer session.
It turned out that the permissions and ownership of the shadow file were incorrect. Not sure how that happened.
Consequently when the password was changed it was putting the new passwords in the wrong place where they weren't used.
After correcting this the password can now be changed correctly.
Message 17 of 19
key5000
Hello mdgm
Thank you very much for remote to my device and fixing the problems, everything is working as it is now.
Thanks a million, mdgm.
Regard,
Key
Message 18 of 19
mdgm-ntgr
You're welcome
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 3277 views
  • 0 kudos
  • 4 in conversation
Announcements
