× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Can't add Camera after 6.6.0 update
clinford
Have a 314 and after the 6.6.0 update now can't get a new IP Camera to work with the readynas surveillance app.
I can search and add the Camera ok but can't when try and set the Camera to connect it does for about a second and then disconnects. I have tried rebooting and no change.
We have already 3 cameras so removed one to see that would get the new Camera to work no change.
I can view the Camera direct via it's internal webpage fine.
Tied the Camera on an older NAS 102 running 6.5.0 and worked fine.
Model: RN31222E|ReadyNAS 300 Series 2- Bay
Message 1 of 10
Accepted Solutions
evan2
NETGEAR Expert
Re: Can't add Camera after 6.6.0 update
Don't remove the settings and recorded video after update to new version.
Message 10 of 10
All Replies
evan2
NETGEAR Expert
Could do please tell me your camera's model?
Message 2 of 10
clinford
Hi Evan2,
it is a Hikvision DS-2CD2122FWD-IWS and works with the RN102 fine, we have other Hikvision's and works fine.
Message 3 of 10
evan2
NETGEAR Expert
Could do please tell me surveillance app's verion are you using?
Could do please update to the latest APP? The latest APP version is v. 1.4.3-15.
Message 4 of 10
clinford
It is Firmware Version: 1.1.1. I can't appear to update it from the Apps on the App section of the NAS
Message 5 of 10
evan2
NETGEAR Expert
Version 1.1.1 is too old,
Let me check with Netgear's app server mamager why there is not update.
Message 6 of 10
Guru
You can manually download it from https://community.netgear.com/t5/Current-NETGEAR-and-Partners/NETGEAR-app-compatibility-with-ReadyNA...
Then upload it on the apps page of the web ui.
Message 7 of 10
clinford
Thanks StephenB,
If I install this over thr current version will it remove the settings and recorded video ?
Message 8 of 10
Guru
@clinford wrote:
Thanks StephenB,
Honestly I don't know - its not an app I use.
Message 9 of 10
evan2
NETGEAR Expert
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2540 views
  • 0 kudos
  • 3 in conversation
Announcements
