- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't create snapshots anymore after successful disk expansions -> "Failed to create snapshot"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
I recently expanded our Raid 6 setup from 4x3TB to 4x10TB which worked as expected. Snapshots were pruned before due to full disks - now after the expansions I was surprised to see that snapshots still got 0% of the overall disk volume even it is enabled to do a hourly snapshot. Creating a snapshot manually resulted into an "Failed to create snapshot" error message.
status.log
[18/02/12 12:37:13 CET] warning:snapshot:LOGMSG_SNAPSHOT_CREATE_WARN Failed to create snapshot initial for share or LUN 'eguoffice'.
system.log
Feb 12 12:37:13 io snapperd[3394]: THROW: stat on info directory failed Feb 12 12:37:13 io snapperd[3394]: reading failed Feb 12 12:37:13 io snapperd[3394]: THROW: stat on info directory failed Feb 12 12:37:13 io snapperd[3394]: CAUGHT: stat on info directory failed Feb 12 12:37:13 io msmtpq[8822]: mail for [ -C /etc/msmtprc barsch@egu.eu --timeout=60 ] : send was successful Feb 12 12:37:45 io snapperd[3394]: THROW: stat on info directory failed Feb 12 12:37:45 io snapperd[3394]: reading failed Feb 12 12:37:45 io snapperd[3394]: THROW: stat on info directory failed Feb 12 12:37:45 io snapperd[3394]: reading failed Feb 12 12:37:45 io snapperd[3394]: THROW: stat on info directory failed Feb 12 12:37:45 io snapperd[3394]: reading failed Feb 12 12:37:45 io snapperd[3394]: THROW: stat on info directory failed Feb 12 12:37:45 io snapperd[3394]: reading failed
Any ideas?
Thanks,
Robert
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:
creating test share & manual snapshot works
That suggests that if a better solution doesn't emerge, that a brute-force approach should work.
- create a temp share (matching the access settings)
- copy the files into it (perhaps with a backup job)
- delete the original share
- rename the temporary share to match the original
Have you checked to see if this issue affects all your shares, or if it only affects some of them?
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't create snapshots anymore after successful disk expansions -> "Failed to create sna
What firmware are you running?
Can you try creating a test share, and see if snapshots work correctly on it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
firmware 6.9.2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
yeah it effects all existing shares - if there is no better solution I will go for the brute force suggestion - thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
after moving all files into antother share I am not able to delete the old share - I tried resetting permissions etc. but still no success - the error messages are the same in the logs:
Feb 12 16:51:21 io snapperd[3336]: THROW: stat on info directory failed Feb 12 16:51:21 io snapperd[3336]: reading failed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Likely you will need Netgear's help on this. They might offer to take a look at your system here, but you might need to use paid support.
Alternatively start over (either factory default, or destroy/recreate the volume) and restore all the data from backup. Painful, but guaranteed.
