Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't find path for shares
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-05
10:13 AM
2013-01-05
10:13 AM
Hi Everyone
I've had my ReadyNAS Duo v2 for four months now, and everything has worked perfectly until now. But after I disconnected and connected the power to my NAS yesterday I can no longer gain acces to the shares.
The log gives following information:
Sat Jan 5 19:12:47 PST 2013System is up.
Sat Jan 5 19:12:46 PST 2013The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. media backup
Sat Jan 5 19:11:57 PST 2013Volume scan failed to run properly
I've tried to upgrade the firmware, but that did not work.
I can see the NAS on the network and have no problem connecting to the NAS using https://192.168.1.109/admin/index.html
I've not changed any settings from during the time the NAS worked and until now.
What to do next?
/Kristian
What to do next?
/Kristian
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-05
10:01 PM
2013-01-05
10:01 PM
Re: Can't find path for shares
Maybe the partition's table lost when you disconnected power directly.
Could you send logs follow below steps?
http://www.readynas.com/kb/faq/misc/how ... d_all_logs
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-06
04:57 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-06
05:22 PM
2013-01-06
05:22 PM
I see your logs, the device's partition table lost, please contact technical support, let them remote control your device to recover the partition table.
Disk /dev/sda doesn't contain a valid partition table
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Disk /dev/sdb: 1000.2 GB, 1000204886016 bytes
256 heads, 63 sectors/track, 121126 cylinders, total 1953525168 sectors
Device Boot Start End Blocks Id System
/dev/sdb1 1 1953525167 976762583+ ee GPT
Disk /dev/md0: 4293 MB, 4293906432 bytes
2 heads, 4 sectors/track, 1048317 cylinders, total 8386536 sectors
Disk /dev/md1: 536 MB, 536858624 bytes
2 heads, 4 sectors/track, 131069 cylinders, total 1048552 sectors
Message 4 of 4
