× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Change Samba idmap with AD
cs_giuseppe
Apprentice
Hi
I have a nas that was installed long ago with a firmware pre 6.5 and then upgraded to the last, with this nas the idmap with ad is different that one started with a recent firmware.
It's possible change the way idmap work to the same automatic behaviour like in the new firmware, having in smb.conf from idmap config * : backend = tdb to idmap config * : backend = rid?
smb.conf is autogenerated so it cannon be modifiied
Thanks
Model: RN31600|ReadyNAS 300 Series 6- Bay
Message 1 of 10
Accepted Solutions
cs_giuseppe
Apprentice
Re: Change Samba idmap with AD
Hi,
SOLVED !!!
here the step
  • Switch from AD to Local users.
  • NEW - Disabled samba in each share
  • Wipe the permissions under File access tab / reset of each shares settings section.
  • Edit /etc/samba/smb.conf to replace tdb by: rid
  • Execute: net cache flush
  • NEW - Reboot
  • Join AD with "trusted domain" unchecked.
After these steps now idmap use rid.
Thank for all suggestions
Message 10 of 10
All Replies
jak0lantash
Mentor
I would:
If smb.conf still uses tdb, I can try to confirm how to manually change it.
Message 2 of 10
cs_giuseppe
Apprentice
Hi jak0lantash,
thank for the suggestion
made:
  • Switch from AD to Local users - done
  • Set file owner to guest and group owner to guest - done
  • Wipe the permissions under File access tab / reset of each shares settings section. - done
  • Deleted the nas account on domain - done
  • Join AD with "trusted domain" unchecked. - done
  • Check smb.conf that it's using rid instead of tdb. - NO, still  idmap config * : backend = tdb
I
Message 3 of 10
jak0lantash
Mentor
 I wish this would behave differently...
Try to edit smb.conf to replace tdb by: rid
Then: net cache flush
Then start the steps again. If you get to rid, the mapping table should be calculated consistently across both devices.
Message 4 of 10
cs_giuseppe
Apprentice
Hi
tried it but no change, still tdb
Thanks
Message 5 of 10
jak0lantash
Mentor
Please confirm if these are the steps you followed:
Message 6 of 10
cs_giuseppe
Apprentice
Hi,
I'm setting a test enviroment with a virtualbox nas for testing so I don not touch many the main production nas.
Keep you updated
Thanks for all support
Message 7 of 10
cs_giuseppe
Apprentice
Hi
I made all on the test nas:
but nothing, still tdb
I founf when the problem arise, with fw 6.5.0 there are problem with ad auth and I check 'trusted domian' this set the tdb and now even is uncheced no rid.
Message 8 of 10
jak0lantash
Mentor
Before 6.5.0, it used tdb.
Since 6.5.0, if trusted domain is unchecked, it uses rid.
Since 6.5.0, if trusted domain is checked, it uses tdb.
Once it starts using tdb, the GUI doesn't allow you to switch back to rid.
Message 9 of 10
cs_giuseppe
Apprentice
Hi,
SOLVED !!!
here the step
  • NEW - Reboot
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 8651 views
  • 2 kudos
  • 2 in conversation
Announcements
