Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Checking for updates makes admin gui unresponsive?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-12
05:15 PM
2015-06-12
05:15 PM
I had updated the firmware to 6.2.something a while ago and it was the version that had the nasty bug that if you removed an app it would hose your NAS. So NetGear support fixed the app removal and the NAS is back. It's been fine for a while (months).
I figured since it's at 6.2.2 right now, I might see about updating to the latest firmware (BTW it's a ReadyNas 312).
But every time I click on the "check for updates", it makes the Web GUI report that the device is offline (takes a few minutes of no response).
Apache IS running.
If I reboot the NAS everything comes back.
Is it not possible to update?
Is there a CLI method to fetch the update and update that way?
Apache IS running.
Message 1 of 4
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-12
06:07 PM
2015-06-12
06:07 PM
Re: Checking for updates makes admin gui unresponsive?
# cd /root
# wget url
# unzip filename.zip
# ls
# echo /root/ReadyNASOS-6.2.4-x86_64.img > /etc/.flash_update
Then reboot the NAS.
It shouldn't go offline like that. Have you checked to make sure your network settings correct? If you have set a static I.P. address you should check that you set DNS correctly etc.
Message 2 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-13
07:50 AM
2015-06-13
07:50 AM
mdgm wrote:
# cd /root
# wget url
# ls
Thanks I will try that. when the device goes "offline", it's only the web GUI. You can still access the Shares/etc. just fine.
Message 3 of 4
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-13
07:54 AM
2015-06-13
07:54 AM
Heh, I forgot to set the DNS server when I had reset the ReadyNas a while back due to the bad 6.2.x upgrade that hosed the unit. Go figure.
However, you'd think the web GUI could reply with "failed to contact NetGear to check for updates" instead of taking the entire admin portion offline.
Message 4 of 4
