Kris_Nalej
Mar 21, 2017Aspirant
Default gateway to Internet
ReadyNas RN4220 has 6 network adapters.
Each one can be connected to a different subnet.
Only one subnet has a connection to the Internet.
How to set the default gatewey to Internet ?
ReadyNas can't check for updates or connect to ReadyCloud because
default gateway is set to the wrong ethernet adapter.
I use static configuration.
Firmware version 6.6.1
- jak0lantashMentor
The configuration UI for this is stupid imo.
Set the default gateway on the correct interface, set 0.0.0.0 on all the other interfaces (or leave empty, don't remember if that is supported now).
- Kris_NalejAspirant
Thank you for the answer.
Unfortunately seting 'router' to 0.0.0.0 = empty doesn't help.
Connection to the Internet works only when one ethernet card is configured.
In my opinion only some command line (ssh) configuration can help.
- jak0lantashMentor
That's the way I configured my RN312.
First NIC in the main subnet with gateway and Internet connectivity, second NIC in a secondary subnet without gateway and no Internet connectivity, and it works for me.
Via SSH, can you give the output of
netstat -rn
I'll check later today the exact configuration from the GUI.
- jak0lantashMentorFor a permanent solution, you should look for the correct config using the GUI. Otherwise, your modifications can potentially be overwriiten by ReadyNASd at next boot, or next write interaction with the config.
I have a similar problem with my RN626X and I wonder if it is related to the order in which the bonds were created. The RN626X has 2 x 1 Gb interfaces, eth0/1, and 2 x 10 Gb interfaces, eth2/3. I created bond0 using the 10 Gb interfaces and bond1 using the 1 Gb interfaces. bond0 connects to an isolated network used for iSCSI only. bond0 is configured with a router address of 0.0.0.0. bond1 connects to a network with Internet access. bond1 is configured with a router address that points to my firewall. DNS for bond1 points to the same firewall.
Everything was working fine until I installed 6.7.0 last night. After that, I could only access my ReadyNAS from networks to which it is directly connected. While searching for a solution I found this discussion. I was able to correct the problem by enabling ssh and using ip route to change the default gateway, but I don't think that is a permanent solution.
I can't figure out how to use the GUI to make the change stick. I thought I might try deleting and recreating the bonds so that bond0 uses the 1 Gb NICs and bond1 uses the 10 Gb NICs, but I'm open to suggestions.
Yes, it's trure that after update 6.7.0 you could only access ReadyNAS from networks to which it is directly connected.
I have the same issue.
The solution is to add each subnet to 'routes' in GUI ( menu 'Network' than tab 'Routes'). It's worked for me.
Unfortunetly I have still problem to acces the Internet. :(
