- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disk upgrade
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
My RN20400 is running OS 6.6.0, drives are in X-RAID mode
It used to have 4 drives in this configuration:
2TB | 4TB | 4TB | 4TB
I needed to upgrade the space, so I removed the 2TB disk, and replaced it with a 6TB disk (Seagate ST6000VN0021 IronWolf NAS). When it got done with the resync, it was still reporting 9.08TB total capacity. I was expecting something closer to 10.8TB. Is there something else that I need to do?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I tried replacing the disk, and no dice. It resynced the array, but didn't expand it. I finally just decided to do a backup of the config, did a factory reset, and restored the config and put my data back on. 10.9 TB total space now.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disk upgrade
@Laserbait wrote:
Hello,
I agree that is what you should be getting (12 TB, ~10.9 TiB).
Did you reboot the NAS after the resync? That might trigger the vertical expansion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disk upgrade
Yeah, I did. I thought I read somewhere here that a reboot was needed, but I can't remember where exactly (I need to bookmark more!).
Maybe another reboot will help shove it along in the right direction. I really hope I don't have to nuke it, and start all over again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disk upgrade
Usually a reboot is only needed the first time a new RAID layer is added. But that doesn't really apply to your case, the second RAID-layer was already in use on the three 4 TB drives.
But still, a couple of reboot tries might kick-start it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disk upgrade
So I rebooted and even did a full power cycle, no joy. Still 9.08TB.
Now this looks a lot like my issue:
Maybe mdgm could lay some of his wisdom upon me. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disk upgrade
Another thing you could try is removing the drive and adding it again. The NAS should detect it as "used" so you'd need to format it in order to add it to the volume.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disk upgrade
Hi Laserbait,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
