- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Drive Tray Screws
- Mark as New
- Bookmark
- Subscribe
- Permalink
On this and this thread you tell users to contact you with their case number (4566674) after contacting support. Like others, I too was told that Netgear don't provide screws or have detail of their spec.
They were clueless and just advised the obvious. Please help!!!
PS - I'm UK, though if necessary, what do you think of this link previously posted?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello daztrue,
Thanks for getting back.
Mdgm is correct, your case number is 25550932 where you have spoken with one of the support people. Unfortunately your ReadyNAS is out of warranty so they could not give you disk screw replacement.
We apologize if you were not given details about the disk screws. It is part number 370-10001-01 for 20 pcs and 370-10002-01 for 100 pcs. available for purchase from support center if you are from the US, unfortunately not in UK.
The disk screw is a 6-32 thread 4mm long countersunk flat head
Here are some resellers I found online:
Hope this helps you.
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Drive Tray Screws
Hello daztrue,
NETGEAR support team sends mounting screws if the NAS is under warranty. If the NAS is out of warranty but registered, you get an option of buying the screws. If your NAS is not registered or cannot be registered, you can purchase the mounting screws from authorized resellers, ask the support center for the part number.
Were you given a case number? Maybe I can check here what happened.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My case number is 4566674.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is your customer number not your case number. The case number is 25550932
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those are not the right head pitch. Go to Amazon and search for Supermicro 3.5" screws.
I also have a supply I got elsewhere. But when I found that these worked, I stopped sending any out. It wasn't worth my effort considering the Amazon price ($6.75 for a bag of 100).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello daztrue,
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is absolutely NOT a standard flat-head screw. The pitch of the countersink is non-standard (standard is 82 degrees). On the old forum, there was a mechanical drawing that showed the proper pitch. I have searched for it (using the horrible search engine this new forum provides) and can only find references to the original message, not the original itself. But those references were not converted when the forum was moved, so they are all now worthless. The system hosting the drawing may be down by now, anyway. But if I remember right, the proper pitch is something like 105 degrees. The "undercut" 82 degree version can be made to work if you don't mind deforming the tray or enlarging the hole a bit, but not really well (they still scrape when the tray is inserted or removed). I have seen 120 degree ones, which are really flat and probably would work. But most places want $0.30 or more each for them unless you buy a case.
Also, the links you provided are to vendors selling trays (with screws), not just selling screws.
The Supermicro screws http://www.amazon.com/Supermicro-Screw-Label-3-5-Inch-MCP-410-00005-0N/dp/B00353EKR8 are the best solution for those who cannot get them from NetGear. The countersink pitch is identical and, while slightly longer, they work just fine. $6.80 for 100 (as of this writing) and they even come with labels you can use to mark the drive order.
