Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Duo V2 - RAIDiator 5.3.5 - proftpd config problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-05-31
04:32 AM
2012-05-31
04:32 AM
Hi,
There is a problem with the configuration of proftpd.
When you have 2 user with the same right in a share (for example : toto and titi in READ ONLY on 'media' ) , only the first user see the share.
So, there is a problem with proftpd .
see : http://www.proftpd.org/docs/howto/Limit.html
So, the file generate by the nas is (/etc/frontview/proftpd/Shares.conf) :
<Directory "/home/ftp/backup">
HideFiles none
<Limit ALL>
Order allow,deny
Deny from all
AllowUser "llevet","toto"
</Limit>
<Limit READ>
Order allow,deny
Deny from all
</Limit>
<Limit WRITE>
Deny from all
</Limit>
</Directory>
With this config , user toto dont see the share "backup" under ftp.
But when i modify the file by :
HideFiles none
<Limit ALL>
Order allow,deny
Deny from all
AllowUser "llevet"
AllowUser "toto"
</Limit>
<Limit READ>
Order allow,deny
Deny from all
AllowUser "llevet"
AllowUser "toto"
</Limit>
<Limit WRITE>
Deny from all
</Limit>
</Directory>
Then all is good.
This problem occur with USER and GROUP to .
So replace the inline AllowGroup or AllowUser by multi lines like upper in the config file.
Thank to modify the firmware to take care of this problem with proftpd.
Thank's.
Ludo.
This is a known issue, and a proper, thorough solution is being developed. In the meantime, however, there is a workaround for allowing multiple users via the AllowUser directive. Rather than listing the users using a single AllowUser, using a separate AllowUser for each user. For example, instead of:
AllowUser bob,dave,wendy
try using:
AllowUser bob
AllowUser dave
AllowUser wendy
HideFiles none
<Limit ALL>
Order allow,deny
Deny from all
</Limit>
<Limit READ>
Order allow,deny
Deny from all
</Limit>
<Limit WRITE>
Deny from all
</Limit>
</Directory>
HideFiles none
<Limit ALL>
Order allow,deny
Deny from all
AllowUser "llevet"
AllowUser "toto"
</Limit>
<Limit READ>
Order allow,deny
Deny from all
AllowUser "llevet"
AllowUser "toto"
</Limit>
<Limit WRITE>
Deny from all
</Limit>
</Directory>
Then all is good.
Thank's.
Ludo.
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-01
12:52 AM
2012-06-01
12:52 AM
Re: Duo V2 - RAIDiator 5.3.5 - proftpd config problem
Good proposal ,we will check this.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-02
07:28 PM
2012-06-02
07:28 PM
Couldn't get this fix working initially..
I noticed when you restart the ftp service the config file goes back to scratch... the reload function via ssh does the trick
thanks...
thanks...
Message 3 of 3
