Orbi WiFi 7 RBE973
Reply
FrontView not accessible
simbo
Hi,
I think I previously found a similar thread but can't find it now.
On my NV+, FrontView is not accessible on but the SMB services are. No problems at all accessing files using SMB as usual, but browser times out on port 80.
The ReadyNas shows up on RAIDar with a version number of 4.1.9 and has the correct IP address.
I've had to power cycle the ReadyNas recently as it was moved and I suspect that the reboot may have triggered an upgrade. Last time it was power cycled was over a year ago.
Here's the output from nmap:
Starting Nmap 6.01 ( http://nmap.org ) at 2012-10-26 03:16 tra
Nmap scan report for readynas.internal.10fifteen.com.au (172.16.2.10)
Host is up (0.0076s latency).
Not shown: 990 closed ports
PORT STATE SERVICE
21/tcp open ftp
111/tcp open rpcbind
139/tcp open netbios-ssn
445/tcp open microsoft-ds
631/tcp open ipp
2049/tcp open nfs
3689/tcp open rendezvous
8000/tcp open http-alt
8200/tcp open trivnet1
50000/tcp open ibm-db2
MAC Address: 00:0D:A2:01:7A:A9 (Infrant Technologies)
Cheers,
Simon.
Message 1 of 3
mdgm-ntgr
NETGEAR Employee Retired
Re: FrontView not accessible
Do you have SSH access?
Do you have any add-ons installed?
Message 2 of 3
simbo
No SSH access. I used to have it, but it got disabled along the way sometime (hence the nmap to check if it's still there).
It appears that there is some other addon that I've installed on port 8000 (AVeL Link Player 2?)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1100 views
  • 0 kudos
  • 2 in conversation
Announcements
