Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Frontview reports replaced disks as dead
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-18
12:23 PM
2013-01-18
12:23 PM
I have a ReadyNAS Pro Pioneer. Recently I had a disk failure. Disk3 was reported as dead in Frontview. In fact it was intermittently working. Then disk2 was reported as dead, and it really was dead, I think. Both disk 2 and disk 3 continued to be reported as dead on Frontview (Status / health) whether or not the display on the unit itself indicated the disks were dead, and whether or not the volume was actually accessible.
I replaced disk2, and the volume became accessible and redundant / protected. The boot logs do not indicate any issues with any of the disks now. Frontview / Status / health still reports disk 2 and disk 3 as dead. The SMART+ buttons are greyed out, the indicator lights on Frontview for 2 and 3 are blinking yellow and the status column says "dead".
It seems that something has latched this failed disk status into Frontview - how can I reset the status to reflect the real status of the working disks?
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-18
05:23 PM
2013-01-18
05:23 PM
Re: Frontview reports replaced disks as dead
Can you post the mdstat and disk_smart logs?
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-18
05:44 PM
2013-01-18
05:44 PM
Sorry - posted wrong disksmart file - deleting.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-18
05:45 PM
2013-01-18
05:45 PM
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 sdd5[8] sda5[0] sde5[6] sdf5[4] sdc5[2] sdb5[7]
7302086480 blocks super 1.2 level 5, 16k chunk, algorithm 2 [6/6] [UUUUUU]
md1 : active raid6 sdd2[6](S) sda2[0] sdf2[5] sde2[4]
2096896 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/3] [U___UU]
md0 : active raid1 sdb1[8] sdd1[7] sda1[0] sde1[6] sdf1[4]
4194292 blocks super 1.2 [6/5] [UUU_UU]
unused devices: <none>
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-01-18
05:48 PM
2013-01-18
05:48 PM
***** smartctl output for sda *****
smartctl 5.42 2011-10-20 r3458 [x86_64-linux-2.6.37.6.RNx86_64.2.4] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Seagate Barracuda 7200.11
Device Model: ST31500341AS
Serial Number: 9VS2FDRG
LU WWN Device Id: 5 000c50 015579bce
Firmware Version: CC1H
User Capacity: 1,500,301,910,016 bytes [1.50 TB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Fri Jan 18 19:41:26 2013 CST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 617) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 61515058
3 Spin_Up_Time 0x0003 100 100 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 69
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 10
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 146976889
9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 27798
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 69
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 580
190 Airflow_Temperature_Cel 0x0022 059 047 045 Old_age Always - 41 (Min/Max 34/46)
194 Temperature_Celsius 0x0022 041 053 000 Old_age Always - 41 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 036 015 000 Old_age Always - 61515058
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 43460774096021
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 3864903375
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 963865024
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 0 -
# 2 Short offline Completed without error 00% 0 -
# 3 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** smartctl output for sdb *****
Serial Number: 9VS5AWQV
LU WWN Device Id: 5 000c50 04d11d764
Firmware Version: CC4H
ATA Version is: 8
been run.
data collection: ( 609) seconds.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 115 100 006 Pre-fail Always - 87951690
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 11
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 062 060 030 Pre-fail Always - 1612293
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 76
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 11
189 High_Fly_Writes 0x003a 098 098 000 Old_age Always - 2
190 Airflow_Temperature_Cel 0x0022 057 054 045 Old_age Always - 43 (Min/Max 36/46)
194 Temperature_Celsius 0x0022 043 046 000 Old_age Always - 43 (0 13 0 0 0)
195 Hardware_ECC_Recovered 0x001a 047 030 000 Old_age Always - 87951690
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 161946036863052
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1724540688
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3204953164
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for sdc *****
Serial Number: 9VS2FDL4
LU WWN Device Id: 5 000c50 015578578
ATA Version is: 8
See vendor-specific Attribute list for marginal Attributes.
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 117 099 006 Pre-fail Always - 135499481
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 70
5 Reallocated_Sector_Ct 0x0033 098 098 036 Pre-fail Always - 87
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 143952440
9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 27797
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 70
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 20 (2, 3)
189 High_Fly_Writes 0x003a 077 077 000 Old_age Always - 23
190 Airflow_Temperature_Cel 0x0022 057 044 045 Old_age Always In_the_past 43 (0 183 47 37 0)
194 Temperature_Celsius 0x0022 043 056 000 Old_age Always - 43 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 039 015 000 Old_age Always - 135499481
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 836
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 836
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 18
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 273615186586773
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 894340112
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1910954751
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for sdd *****
Serial Number: 9VS5AC8Y
LU WWN Device Id: 5 000c50 04086e09b
ATA Version is: 8
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 100 100 006 Pre-fail Always - 3032119
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 2
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 3
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 157857
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 12
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 2
189 High_Fly_Writes 0x003a 097 097 000 Old_age Always - 3
190 Airflow_Temperature_Cel 0x0022 059 056 045 Old_age Always - 41 (Min/Max 21/44)
194 Temperature_Celsius 0x0022 041 044 000 Old_age Always - 41 (0 21 0 0 0)
195 Hardware_ECC_Recovered 0x001a 033 033 000 Old_age Always - 3032119
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 25786983645196
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2795211074
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3244288831
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for sde *****
Serial Number: 9VS1ESRD
LU WWN Device Id: 5 000c50 0112b54bb
ATA Version is: 8
Local Time is: Fri Jan 18 19:41:27 2013 CST
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 115 099 006 Pre-fail Always - 92275438
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 59
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 20
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 147255192
9 Power_On_Hours 0x0032 069 069 000 Old_age Always - 27440
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 59
189 High_Fly_Writes 0x003a 050 050 000 Old_age Always - 50
190 Airflow_Temperature_Cel 0x0022 056 043 045 Old_age Always In_the_past 44 (2 136 47 38 0)
194 Temperature_Celsius 0x0022 044 057 000 Old_age Always - 44 (0 18 0 0 0)
195 Hardware_ECC_Recovered 0x001a 041 019 000 Old_age Always - 92275438
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 198363064593199
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2483375488
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1267825656
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for sdf *****
Serial Number: 9VS2FJWX
LU WWN Device Id: 5 000c50 0155b61d7
ATA Version is: 8
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 114 099 006 Pre-fail Always - 71841947
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 30
7 Seek_Error_Rate 0x000f 081 060 030 Pre-fail Always - 144333425
189 High_Fly_Writes 0x003a 073 073 000 Old_age Always - 27
190 Airflow_Temperature_Cel 0x0022 058 045 045 Old_age Always In_the_past 42 (Min/Max 36/46)
194 Temperature_Celsius 0x0022 042 055 000 Old_age Always - 42 (0 17 0 0 0)
195 Hardware_ECC_Recovered 0x001a 036 012 000 Old_age Always - 71841947
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 256138964659349
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 599029890
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 1055458111
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Message 5 of 5
