- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to connect automaticly as vpn client in readey nas 104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello i'm using a vpn server and i would like to know how to connect my ready nas automaticly when the nas boot, i'm using hide my a** as vpn service and using the hma script too.
For the moment i have to connect in ssh and ./hma-bla-bla.sh -d (-d for daemonize).
here is the script i'm using for the moment, i had to remove all "sudo" cmd because im connecting as root to my nas,i have to login and select the server manually.
trap ctrl_c INT
function ctrl_c() {
echo
echo "Exiting script..."
echo
stty echo
exit 0
function showhelp()
echo "- Available switches:"
echo "./hma-openvpn.sh -h = Show help"
echo "./hma-openvpn.sh -d = Daemonize OpenVPN"
echo
echo "- Please ensure to have this packages installed:"
echo " curl, openvpn, wget, dialog"
echo " e.g.: yum install curl openvpn wget dialog"
echo " or: apt-get install curl openvpn wget dialog"
echo
while getopts "dh" parm
do
case $parm in
d)
daemonize=1
?) echo
echo "HMA-OpenVPN Script"
echo "=================="
echo
showhelp
exit 0
esac
done
showtitle() {
clear
green="\e[36;5;82m"
stdcol="\e[0m"
echo
echo -e "$green =============================="
echo " | __ ____ ______ __ |"
echo " | / / / / |/ / | / / |"
echo " | / /_/ / /|_/ / /| | / / |"
echo " | / __ / / / / ___ |/_/ |"
echo " | /_/ /_/_/ /_/_/ |_(_) |"
echo " | |"
echo " | HMA! OpenVPN Script |"
echo " =============================="
echo
echo "-> https://hidemyass.com/vpn"
echo -e "-> https://support.hidemyass.com$stdcol"
echo
showtitle
showhelp
sleep 3
echo "- Getting HMA! Pro VPN serverlist..."
sleep 1
wget -q http://hidemyass.com/vpn-config/l2tp/ -O /tmp/serverlist.txt
LINES=$(cat /tmp/serverlist.txt)
IFS=$'\n\t'
dialog --backtitle "HMA! OpenVPN Script" \
--title "Select a server" \
--menu "Select a server" 17 78 15 $LINES 2>/tmp/hma-server
unset IFS
sleep 1
hmaserver=`cat /tmp/hma-server`
clear
--title "Select protocol" \
--radiolist "Use OpenVPN-TCP (port 443) or OpenVPN-UDP (port 53)?" 10 40 3 UDP "" on TCP "" off 2>/tmp/hma-proto
sleep 1
showtitle
hmaproto=`cat /tmp/hma-proto | tr '[:upper:]' '[:lower:]'`
echo "- Getting .ovpn template..."
echo
sleep 1
wget -O /tmp/hma-template.ovpn http://hmastuff.com/hma-template.ovpn
echo "proto $hmaproto" >> /tmp/hma-template.ovpn
if [ "$hmaproto" == "udp" ]; then
echo "remote $hmaserver 53" >> /tmp/hma-template.ovpn
hmaport=53
fi
if [ "$hmaproto" == "tcp" ]; then
echo "remote $hmaserver 443" >> /tmp/hma-template.ovpn
hmaport=443
fi
showtitle
function checkip()
ip=""
attempt=0
while [ "$ip" = "" ]; do
attempt=$(($attempt+1))
ip=`curl http://geoip.hidemyass.com/ip/ 2>/dev/null`
if [ "$ip" != "" ]; then
echo "- Your current IP is: $ip"
fi
if [ $attempt -gt 3 ]; then
echo "- Failed to check current IP address."
exit
fi
done
checkip
sleep 1
echo
echo "- Starting OpenVPN connection to: $hmaserver : $hmaport ($hmaproto) ..."
sleep 1
echo
if [ "$daemonize" == "1" ]; then
openvpn --daemon --script-security 3 --config /tmp/hma-template.ovpn
echo
echo "Waiting 10 seconds for doing IP-check..."
sleep 10
echo
checkip
echo
echo "Disconnect via: sudo killall openvpn"
echo
else
openvpn --script-security 3 --config /tmp/hma-template.ovpn
fi
tput sgr0
exit 0
thanks for the help
basicly i would like the script try to connect when i have internet connection, when the power get back in the house for example, wait 1 minute after boot or try to ping google or any website before trying to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to connect automaticly as vpn client in readey nas 104
Hello wizhack,
This was posted in August, it appears that something has been changed and done from the backend. I guess it is best to wait for other community members to share their thoughts and experience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello wizhack,
Have you received any feedback from any of the members?
