Orbi WiFi 7 RBE973
Reply
Installed Disk 3 + 4... don't know what to do to make them work.
Barbarenbaer
Hi,
I had two 4TB disk (RAID 1) in my RN42600. I now added two 2TB disk to get more storage. Disk are found, I formated them, but I don't know how to add them. Selecting one and clicking expand does nothing but hide the buttons. I don't really care if the added disks are used as RAID 5 with the existing ones or create a different volume.
Model: ReadyNAS-OS6|
Message 1 of 2
Accepted Solutions
Guru
Re: Installed Disk 3 + 4... don't know what to do to make them work.
They have to be in a different volume - they'd have to be 4 TB or larger to be used with your existing array.
Turn X-RAID off, by clicking on the X-RAID control on your screen shot.
Then you can create a new volume (for instance RAID-1).  Select the two new disks, and you should see an option to do that.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 583 views
  • 0 kudos
  • 2 in conversation
Announcements
