× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
JBOD (Single)-function (2 HDDs as 2 independent drives) on USB
komm_it
Guide
Hello,
I'm trying to set up a JBOD box  (IcyBox IB-3662U3) with 2 HDD as 2 independent drives on a one of the USB port.
The RN31600 only recognize 1 HDD. Windows or MacOS recognize and mount both Ext4 HDD.
Is there anyway I can make ReadyNAS 6.9.3 system recognize both HDD?
Thanks
Model: RN31600|ReadyNAS 300 Series 6- Bay
Message 1 of 8
Accepted Solutions
Guru
Re: JBOD (Single)-function (2 HDDs as 2 independent drives) on USB
@komm_it wrote:
Well, perhaps a new 4 drives NAS set up as JBOD is actually a better / safer solution…
I think it is safer, but your approach does allow you to remove the drives and access them directly with ext, which is a plus.
Message 8 of 8
All Replies
mdgm-ntgr
NETGEAR Employee Retired
I don't think so.
Btw if you download the logs what is the date in bios_ver.log?
Message 2 of 8
komm_it
Guide
Ok thank you.
Could a newer bios do the job?
/sys/class/dmi/id/bios_date
11/06/2013
Message 3 of 8
mdgm-ntgr
No. In any case you already have the latest BIOS for your ReadyNAS installed.
What the latest BIOS does have is a USB3 F/W update.
Message 4 of 8
komm_it
Guide
Well, actually, after having created sharepoints on both drive separatly (only one drive physically connected at a time) and connecting both drives again, I can see and access (r/w) both sharepoints via SMB and FTPshares.jpg…But the system only recognises 1 physical USB HDDsystem.jpg
Could this set-up be reliable and what could be the possible drawbacks of such a set-up?
Message 5 of 8
Guru
Personally, I think it is better to set up the NAS with enough capacity to hold your data on internal drives.
If the drives are disconnected for some reason (or if the NAS has the power cut) you might end up with "dirty" volumes (due to lost cached writes).   While this can also happen with internal volumes, the risk is higher with external drives.  I suggest protecting the IcyBox and the NAS with a UPS (a single UPS protecting both devices, with the NAS monitoring the UPS over USB).
If you don't have any linux systems (apart from the NAS) you might try installing R-linux for Windows, and see if it can read the volumes (with the Icybox connected to a PC).   https://www.r-studio.com/free-linux-recovery/
Message 6 of 8
komm_it
Guide
Thanks, I understand the risk with power cut and a UPS is definitely a good advice.
We have some free space on the NAS (X-RAID2) but all slots are used and the space left won't cover the need for this particular project
Those external drives are supposed to collect raw pictures from a timelaps system via FTP.
This system will be running over 3 years, accumulating a really large amount of data (raw pict) from 4 differents cameras.
We'd like to use both USB3 port with 4 x 12TB HDD (1 HDD per camera)
The idea by using a USB external JBOD system instead of internal NAS is to be able to easily replace the HDD when they are running out of space.
A JBOD system makes the whole set-up much more flexible. HDD can be stored and used directly on workstations for editing.
Thanks again for your advice
Message 7 of 8
Guru
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1967 views
  • 0 kudos
  • 3 in conversation
Announcements
