douglaswyatt
Sep 03, 2014Aspirant
Manually setting password hashes
Not sure if this is the right place to post this, but I've got a possibly strange question. I'd like to be able to manually set the password hash for users, and I'm not sure if the ReadyNAS OS 6 supports sha512 hashes, or if I'm doing something else wrong. I want to do this because I'd like a user's password to be the same on the ReadyNAS as it is on another Linux box, without having them have to set their passwords twice. I ssh'd in to the box, made /etc/shadow writable, and edited a user's entry to include a password hash created on a different machine (CentOS). It didn't work - I see "FAILED with error NT_STATUS_WRONG_PASSWORD" in the log files. But I noticed that the passwords in /etc/shadow start with a $1 prefix, indicating that they are MD5 hash, while the password I pasted starts with a $6, indicating it's a SHA512 hash. Looking in the /etc/pam.d/common-password file, it appears that SHA512 is the hash of choice for the ReadyNAS:
So I've got two questions:
First, why does it appear that the ReadyNAS is creating MD5 hashes instead of SHA512?
Second, why doesn't it seem to like my cut-and-pasted SHA512 password hashes created on another Linux box?
Thanks!
# Explanation of pam_unix options:
# The "sha512" option enables salted SHA512 passwords. Without this option,
# the default is Unix crypt. Prior releases used the option "md5".
#password [success=1 default=ignore] pam_unix.so obscure sha512
password [success=1 default=ignore] pam_unix.so sha512
Thanks!
- mdgm-ntgrNETGEAR Employee RetiredYou would need to use smbpasswd to change the password for samba I think.
I'm not sure if these changes would survive a reboot. You may also need to edit the readynasd database. - douglaswyattAspirantAh, yes. should have thought of that. I'm used to samba installations that share passwords out of /etc/passwd|shadow. Is there a way to edit the readynasd database? Or am I asking to do something that is fighting too much of the readynas structure?
- mdgm-ntgrNETGEAR Employee RetiredThat is maintained using the sqlite3 command.
You can check if the information is in the database or not by downloading the logs and looking in db.dump
