× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NAS Died
MrPecs
Follower
NAS Died
Hi!
Ive got a problem, my NAS is dead. Its raided with 2 disks to be "safe".
Question is, is it possible to save the data of the disks? Buying a new Radynas or whatever?
10 years ago i lost familyalbums, thats when i bought a NAS. Last check of the NAS two weeks ago the disks where healty and fine, i think its the "motherboard" or powersupply that has died.
Help Smiley Happy
Model: ReadyNAS RND2000|ReadyNAS Duo Chassis only
Message 1 of 3
Guru
Re: NAS Died
@MrPecs wrote:
Its raided with 2 disks to be "safe". ...
RAID isn't enough to keep your data safe - you can only do that if you have backups on other devices.
From your post I am assuming that you have a duo v1.  That runs 4.1.x firmware.  Please confirm the model, using the guide here: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/... The labels are confusing, so please do check the guide.
If you have access to a windows PC, you can install r-linux for windows ( http://www.r-tt.com/free_linux_recovery/ ) and hook up drive 1 to the PC.  If the disk is healthy, it should be able to read the files.
Note you can use a sata->USB adapter for this (so it can be done with a laptop).
Message 2 of 3
Sandshark
Sensei
Re: NAS Died
If it is the power supply, it is quite easy to replace.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 798 views
  • 0 kudos
  • 3 in conversation
Announcements
