× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
NAS not visible on wifi after net router install
luckyinpa
readynas 422.
new netgear ax1800 just installed. when plugged into ethernet, the readynas program RAIDar gives me the correct 192.168.0.107 address that NAS always has had but also gives me a 169.254.xxx.xxx IP address that changes and is not fixed. when i unplug ethernet from the laptop, the RAIDar program only gives me the 192 address. but you cannot get to it thru a browser nor does it show up in file explorer so i cannot do my backups over wifi as i always have.
while plugged into ethernet you can enter the 169 address and get to the NAS both thru browser and file explorer. under my network and sharing center i confirmed network discovery is on private and public.
also in the router setup under attached devices it correctly says the NAS is at the 192 address.
Message 1 of 2
luckyinpa
Re: NAS not visible on wifi after net router install
figured it out . hit reset dhcp on the NAS and it gave it a new IP address and now i'm in with the new address. it also works thru the browser interface too.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 743 views
  • 0 kudos
  • 1 in conversation
Announcements
