Orbi WiFi 7 RBE973
Reply
NET Command high CPU usage
schnax
Apprentice
Hi,
using a RN314 OS 6.5.1  with Engyte Storage Sync. I have observed that when looking at the top running process on the unit that 'net' shows 100%
I had this before at that time there where 3x net running each with 100% CPU and total CPU at over 80%. After a reboot they disappeared.
I'm wondering why net is running, why the CPU is so high and how can this be fixed? Rebooting should be the regular fix for this.
Model: RN31400|ReadyNAS 300 Series 4- Bay
Message 1 of 4
mdgm-ntgr
NETGEAR Employee Retired
Re: NET Command high CPU usage
Are you running any other apps?
Can you send in your logs (see the Sending Logs link in my sig)?
Message 2 of 4
schnax
Apprentice
no other apps than Egnyte running - sent in log files.
Today I see two net proccess each 100% CPU
24192 root 19 -1 277m 4980 2848 R 100.2 0.2 12609:31 net
24713 root 20 0 283m 13m 11m R 99.8 0.7 746:50.58 net
Message 3 of 4
Skywalker
NETGEAR Expert
This may be due to a bug in the MIT kerberos library, that has been fixed in 6.5.2.  If you'd like to wait until 6.5.2 is released before updating, you can update just the kerberos library package by running
apt-get install libkrb5-3
from the command line, assuming your NAS has internet access.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2448 views
  • 0 kudos
  • 3 in conversation
Announcements
