× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Netword Performance issuse
ylafont
Need some guidance on a Networking issues that started a few days ago and I am not sure how to how to troubleshoot.
Problem - Every two minutes or so I lose the ability to access the internet, web surf, streaming audio RDP connections, VOIP call are cut off and so on. This last about 20-30 seconds and then connections are restored.  The odd thing here is, the internet connection stays up and does not appear to be the problem I have monitored the router and all is well, I have called Time warner and had the connection tested.  Although I loose RDP connection, I don’t lose my VPN connection.
Troubleshooting- I disconnected EVERY Device from the network and only attached the PC to the router and the PROBLEM disappeared.  I then began to plug in devices one at a time every two hours or so to see what device was the problem.  After all was said and done, I have identified my READYNAS PRO is the cause of the problem.   Each time I unplug it from the network everything returns to normal.
Just in case there was an IP conflict - I have change the IP.
Just in case the RJ45 cable was bad - I have changes the RJ45 cable
Just in case the NAS Ethernet port went bad - I moved to the secondary Ethernet Port on the device
Just in case the Ethernet port was bad on the switch, the NAS connection was moved to another port.
How can I find the cause of this problem?
Message 1 of 10
Guru
Re: Netword Performance issuse
Are you forwarding ports to the NAS in the router?
Message 2 of 10
ylafont
I do have ports being forwarded on the router- however no ports are being forwarded to the NAS itself.
Message 3 of 10
ylafont
i am curious  the bond0 and  and tun10 interfaces.. are they supposed to be there?
NasOne:~# ifconfig -a
bond0     Link encap:Ethernet  HWaddr 00:00:00:00:00:00
          UP BROADCAST RUNNING MASTER MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
eth0      Link encap:Ethernet  HWaddr 00:1F:33:EA:50:95
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          Interrupt:16 Memory:ff6fc000-0
eth1      Link encap:Ethernet  HWaddr 00:1F:33:EA:50:94
          inet addr:192.168.101.3  Bcast:192.168.101.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:14079467 errors:0 dropped:7 overruns:0 frame:0
          TX packets:2106931720 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3083618709 (2.8 GiB)  TX bytes:2046929944846 (1.8 TiB)
          Interrupt:17 Memory:ff7fc000-0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:26411 errors:0 dropped:0 overruns:0 frame:0
          TX packets:26411 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1811103 (1.7 MiB)  TX bytes:1811103 (1.7 MiB)
tunl0     Link encap:IPIP Tunnel  HWaddr
          UP RUNNING NOARP  MTU:1480  Metric:1
Message 4 of 10
Guru
I see both interfaces on my pro (though in my case I use bond0). I am wondering if tun10 is set up for remote.
What add ons do you have installed?
Message 5 of 10
ylafont
No add-ons install on the NAS.
to be on the safe side, I just turned off
Discovorry Services
ReadyDLNA
AFT protcol
FTP Protocol
The only services running are  CIFS, HTTP, HTTPS
Message 6 of 10
Guru
If you have a scratch disk, you could remove the pro disks (labeling them by slot), and install the install disk.
Then see if the clean factory install has the same problem.
Message 7 of 10
ylafont
Currently moving data of NAS to performe a reset.     NAss has been one for over three years, no changes have been made. How coudl this have happend and more importantly how can it be prevented?
Message 8 of 10
Guru
Its hard to say w/o knowing the cause.
Did you check for a filling OS partition?
Message 9 of 10
ylafont
It took about 10 days for data to copy with wll the network drop offs.   The only wasy to fix this issues for me was to reset to factory default!  Arg!
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 5132 views
  • 0 kudos
  • 2 in conversation
Announcements
