Orbi WiFi 7 RBE973
Reply
Newbie question on ReadyNas Duo - access permissions
kwool
Re: Newbie question on ReadyNas Duo - access permissions
Ok, so that is back to the point of it not letting me in for some reason. Unless, like I said, I am completely thinking this wrong. The admin password is set when I set the NAS up, right? The one that gets me access to the "admin page"? If that is the case, I keep getting denied when running the net use command.
Message 26 of 31
Guru
Yes, the admin credentials are the ones that give you access to the admin web ui.
Are you doing a "net use * /delete" first? Then "net use x:\ \\nasipaddress\data /user:admin", where "x" is the drive letter you want to map to.
Message 27 of 31
kwool
Yes, I used the delete command and that is when I was able to connect to the music folder using the other command. I am starting to think that maybe I am not using the admin account. If I wasn't, would I still be able to connect to the music folder using the net use command? I just don't know why I can't connect to the root.
Message 28 of 31
kwool
ok, FINALLY, got the command completed successfully but when I try to move the .bundle file in to the t:\.apps\plexmediaserver\medialibrary folder, it tells me access denied...I am thinking I have to change attributes on the folder?
I do see now that I have to drill down farther into the Plex folder as well....
Message 29 of 31
kwool
Finally got it!! I was mapping wrong after I got the net use commands fixed. Thanks everyone for the help!!! I know newbies can be a pain!! 🙂
Message 30 of 31
Guru
I'm glad you got it sorted out.
Message 31 of 31
Top Contributors
Discussion stats
  • 30 replies
  • 3750 views
  • 0 kudos
  • 5 in conversation
Announcements
