Orbi WiFi 7 RBE973
Reply
No access to shares after disabling SMB1 as recommended by Microsoft
Guru
Re: No access to shares after disabling SMB1 as recommended by Microsoft
@kohdee wrote:
Alternatively, you can upgrade to a newer ReadyNAS and use the old ReadyNAS as a backup (always smart to have multiple backups, which eliminates single point of failure).
Note that if you do that, you can also disable SMB altogether on the backup NAS.  That's what I've done on my 4.1.x NAS.
Message 26 of 29
shukerr
Tutor
Thanks for the reply. I did see that it's possible to upgrade to OS6, but then saw a mention that the fans may run loud and that would be a problem for me.
Do you know if fan speed is still an issue with the unofficial OS6 on ReadyNAS Pro?
If this is resolved then I'll do the upgrade & factory reset.
Thanks in advance,
Message 27 of 29
Sandshark
Sensei
If you have the stock fans, the problem was resolved a long time ago.  Some who have replaced their fans had problems that persisted longer -- I do not know if those have been resolved.
Message 28 of 29
shukerr
Tutor
Thanks for the info on OS6.
I upgraded my unit to OS6 and all seems well.
Quite a mission to copy all the data off and factory reset it!
Message 29 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 108083 views
  • 3 kudos
  • 12 in conversation
Announcements
