- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OS 6.4.1 slow ... to the point of unusable
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OS 6.4.1 slow ... to the point of unusable
@AdriFrijters wrote:
What about accessibility direct from the internet when you are hacked or access your files from somewhere else?
If you are uploading files from a public PC w/o protection, then the scan wouldn't happen until you accessed the the files from one of your protected windows systems. Since the NAS is running linux, there isn't much risk of damage spreading to other files unless it is being accessed by an OSX or Windows PC).
If a hacker attempts to penetrate the NAS, the AV scanner honestly won't help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can I downgrade from 6.4.2-T59 to 6.4.0 without issues?
If so, what is the correct downgrade procedure?
(Already downloaded ReadyNASOS-6.4.0-x86_64.img on my PC)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just use the manual installation control on the admin web ui (system->services).
- Mark as New
- Bookmark
- Subscribe
- Permalink
http://kb.netgear.com/app/answers/detail/a_id/29938/~/readynas-os-version-6.4.0
this is the position of the OS
- Mark as New
- Bookmark
- Subscribe
- Permalink
He said he'd already downloaded it, so I didn't bother to include the link.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue how do you go back to 6.4.0?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Read the thread, it answers your question.
-download 6.4.0 from the link above
-extract the img file from the zip
-use the web admin ui's "manual install" control on the system->settings page.
But disable the AntiVirus service first, as that will likely be enough to solve your problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have a fix that we would like some user feedback on. If you are interested please disable anti-virus under System > Settings > Service, Update your unit to 6.4.1 and send me a PM.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also had my RN102 that slow to the point of unusable. I went back to 6.4.0 because I can't afford to have the RN off-line or soo slow that it is not usable. Hopfully the next FW-Update will be better. Wenn I read that the antivirus workaround is a go, maybe I will try again...
Just for others with the same problem:
Logon to the admin-page
Unpack the 6.4.0 zip and upload it in settings to the RN
Going back to 6.4.0 is easy!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I disabled 6.4.1's Antivirus and that worked for me; will keep an eye on this forum to know when the fix from NetGear is ready. Thank you to Stephen for all the clear, helpful info you have posted on this subject as well as the positive attitude!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same slowdown issue on my 3130 with 6.4.1.... Turned off the antivirus service and the system came right back to life.
Will wait for the next firmware update instead of downgrading to 6.4.0.
Thanks for the troubleshooting help!
-Steve
- Mark as New
- Bookmark
- Subscribe
- Permalink
We are aware of the issues with Antivirus slowing down the NAS. We've been looking into what we can do to resolve this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mdgm wrote:We have a fix that we would like some user feedback on. If you are interested please disable anti-virus under System > Settings > Service, Update your unit to 6.4.1 and send me a PM.
Hi,
Thanks for taking time to support us.
May I update, that I have my antivirus disabled already, however backing up folder from My PC to Ready Nas has only reached to 567 GB out of the 1.32 TB of Data for more than 24 hours.
My PC is on hooked up on to Giga switch and so is my Ready Nas.
Could you please advise if Im doing anything wrong here?
Also the downgrade option tempeted me, however that fact that I spent so long in transfer and by the way which is still going on will be broken if I try downgrading.
Your help in this reagrds is greatly appreciated as always.
Peace
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I heard / read 6.4.2 is available. Is This correct and is it safe?
It is released, and I've installed on my RN102 and my RN202. No problems so far.
BTW, I did a factory reset on the RN102, and that restored its original performance (in fact write speeds are quite a bit faster than I measured back in the 6.2.x days). I'm seeing 70-75 MB/s on the RN102 (both read and write), and ~100 MB/sec on the RN202.
Both are jbod, not RAID-1.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. A factory default wipes all data.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thnx. For a NAS in use no option (i think). Thanks.
There is some down time.
Restoring the data with rsync took 1 TB per day. I think if you used NFS or CIFS it would have been > 4 TB per day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi amtrakuk1,
There are bugs and issues that were addressed by the Official 6.4.2 Firmware. We highly suggest that we keep are units up to date. With regard to the AV issue, we don't have a fix available at the moment.
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not looking good on the RN 516 either. Installed 6.4.2 update and turned virus checker on again - SLOW again... real SLOW, like the subject says to the point of unusable. Turned off virus checker and all well again.
Please resolve.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well that's no fun. I guess I incorrectly assumed the issue was resolved in 6.4.2.
For anyone else, read the notes (like I didn't).
6.4.2 does NOT fix the virus checker slow issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all!
That’s the answer I was looking for. I'm a bit disappointed because I thought this major bug will be fixed with the 6.4.2. So this version is also useless... Can't believe this is treated like a minor concern... So still running 6.4.0 until the next round.
Br,
Florian
