× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
OS Reinstall added -snap to shares #(17605122) *Solved*
vuilverwerking1
After problems with my ReadyNAS NVX Pioneer i did a OS Re-install.
After this all my shares apear twice with de second name ending with -snap.
Anybody know what to do?
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: OS Reinstall added -snap to shares (Support #17605122)
Work with support on this issue.
"-snap" indicates there is an active snapshot.
Snapshot is not a feature of the Pioneer.
Unless you have the Online Filesystem Check option under Volumes > Volume Maintenance (not sure if this tab is on Pioneer) and it's running you shouldn't have "-snap" shares.
Message 2 of 5
vuilverwerking1
I know that snapshot is only used for the OS.
Thats my problem. 🙂
Message 3 of 5
vuilverwerking1
I did an Online Filesystem Check but de -snap shares don't dissapear.
Message 4 of 5
vuilverwerking1
Re: OS Reinstall added -snap to shares #(17605122) *Solved*
Unplugged the ReadyNAS for 30 minutes.
OS Re-install
Solved.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1099 views
  • 0 kudos
  • 2 in conversation
Announcements
