× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
OS6 home folder access rights reset
aks-2
Apprentice
I am moving data from an NV+ v2 to RN214 via an external backup (USB3), as I need to reuse the drives from NV+.
I have set up the shares and user home folders, and used a backup job to restore the data. Data coming across just fine, but I cannot figure out how to reset access rights and ownership in the home folders from the web UI (like you can with shares).
Via ssh, I see as ownership of files/folders after restore is root:root. I could use chown to fix, but I am not sure if this is how OS6 manages access rights entirely, or if there are other intertangled mechanisms with BTRFS in use, etc.
I also read the only thread I found on home folders / backup / restore, it was from 6 years ago, but it was only a related type of problem and didn't help.
Model: RN214|4 BAY Desktop ReadyNAS Storage, RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 3
Accepted Solutions
Sandshark
Sensei
Re: OS6 home folder access rights reset
chown should take care of it assumoing you actually created the shares by creating the users and then either logging them in or using mkhomedir_helper.  You cannot create a proper user folder by letting a backup restore create it.
Message 2 of 3
All Replies
Sandshark
Sensei
Message 2 of 3
aks-2
Apprentice
Thanks @Sandshark, yes I used the mkhomedir_helper to create the home directories, I was just checking that this was a valid approach with OS6.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1280 views
  • 0 kudos
  • 2 in conversation
Announcements
