Orbi WiFi 7 RBE973
Reply
Permissions Fault
Lusk
Permissions Fault
Hoping you can help me here, please.
I am experiencing problems on some Windows machines when it comes to writing a new file to the NAS.
The NAS is set up on a private internal network and I would like to know how it is possible to set it up so that there are no more faults.
Userwise, I don't appear to have any set up and the system has worked fine like this.When I go to Security > User and Group accounts > all, the only one listed there is "users".
When I go to Volumes > Volume settings > everything is ticked and when I go to the share listing, the relevant share in question has CIFS, NFS and FTP/S highlighted.
Any assistance would be much appreciated.
Model: ReadyNASRND2120|ReadyNAS Duo 2TB (2 X 1TB)
Message 1 of 11
Accepted Solutions
Guru
Re: Permissions Fault
Ok.  Note that OS 4.1 only supports SMB 1.0, which is being deprecated by Microsoft.  So if you have Win10 systems you will either need to manually install the SMB 1.0 client or use NFS.
It sounds like you are already using "user" security mode, and not the older "share" security mode.  The share security mode was deprecated quite a while ago, and if you are using it then you should certainly switch to "user".  Let us know if that's your situation, we can provide some help on how to switch.
Assuming "user" security mode: If your issues are specific to writing files, then I suggest you begin by resetting the file permissions and owners for the shares.  You do this on the share's "advanced options" page in the web ui.  First select the "CIFS" button, and then you will see the "advanced options" tab on the far right.
Set the folder owner/group, and the owner/group/everyone rights.  "nobody" is ok for the owner, and "nogroup" is ok for the group.  I suggest "read/write" for all the rights - these are file permissions, so you can still control access to the share using the network permissions if you like.
Then check both the "Set ownership and permission" box and the "Grant rename and delete" box, and click "apply".  The "set ownership and permission" box will immediately clear - that is normal.  The operations complete in the background - there will be a notification pop-up when it completes (and it will also be on the log page).
Message 6 of 11
All Replies
schumaku
Guru
A little bit vague.
What for you have NFS enabled?
What for you have FTP/S enabled?
You had configured users before, created groups of users with similar access rights, and granted the acess to the shared folders on a group base?
Has it worked before?
Ref. SMB access, Windows does for for a while and on never versions no longer lalow using a non-authennticated access, so the "Anonymous" access can't be used, as Windows does not allow accessing shared folders.
PS. Somehow this post ended in the wrong community area, he REadyNAS does start about here -> ReadyNAS Network Storage e.g. either consider "Using your ReadyNAS" or "New to ReadyNAS". Let's see if we can make a moderator moving this thread @Christian_R please.
Message 2 of 11
Guru
Please tell us what firmware is installed on your NAS.
From your post it sounds like you might have a Duo v1 (which runs 4.1.x firmware).  But it is important that we know with certainty exactly what you are running.
Message 3 of 11
Lusk
For NFS I have default access listed and that is all and for FTP/S, I have exactly the same listed.
Message 4 of 11
Lusk
Thanks for the reply and yes, i can confirm the version is RAIDiator 4.1.16 [1.00a043]
Message 5 of 11
Guru
Message 6 of 11
Lusk
Thank you very much for the in-depth reply but could you please confirm how I would know whether I am in user or share security mode?
Message 7 of 11
Guru
Look on the security->security mode page in the web ui.  If you see a shared security mode option that is checked, then you are using the shared security mode.
If you don't see the SHARED security mode option (or if the security->security mode page is missing) then you are using user security mode.
Message 8 of 11
Lusk
Thanks again and the page is missing. I have carried out the rest as per your previous post on the two NAS's and one has reported back the settings changed and the other has now just changed too.
Will give this a try.
Message 9 of 11
Lusk
Just a quick note to say thanks to StephenB for his assistance here. Having tried to copy files from a machine which previously didn’t work, having run the routine as advised, I can now delete etc.
This has been driving me mad for a while now but it appears to be sorted.
Message 10 of 11
Guru
I'm glad I was able to help. Smiley Happy
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1966 views
  • 3 kudos
  • 3 in conversation
Announcements
