- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAIDar diagnostics
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAIDar diagnostics
I noticed from RAIDar diagnostics the following:
NAS314 Successfully completed diagnostics System Disk 1 has 1 Current Pending Sectors Logs 2017-05-11 15:45:57: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-10 14:30:30: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-09 12:03:11: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-08 14:06:43: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-07 14:33:28: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-06 15:24:26: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-05 07:46:45: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-04 08:33:55: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-03 14:55:22: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-02 17:00:45: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-01 07:56:44: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-30 14:19:36: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-29 14:57:51: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-28 15:34:41: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-27 08:50:49: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-26 14:50:08: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-25 14:59:16: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-24 14:31:03: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-23 16:00:46: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-22 15:35:22: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-21 11:23:35: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-20 09:49:06: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-04-19 09:44:33: home.mount: Directory /home to mount over is not empty, mounting anyway.
PRO Successfully completed diagnostics System Logs 2017-05-25 07:00:38: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-24 11:58:21: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-24 07:00:38: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-23 07:00:38: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-22 07:00:38: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-21 05:53:10: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-20 05:40:48: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-19 07:00:44: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-18 07:00:38: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-17 07:00:38: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-16 07:00:39: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-15 11:12:21: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-15 07:00:39: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-14 07:25:06: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-13 07:22:02: home.mount: Directory /home to mount over is not empty, mounting anyway.
ULTRA Successfully completed diagnostics System Logs 2017-05-25 07:00:40: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-24 11:58:27: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-24 07:00:42: home.mount: Directory /home to mount over is not empty, mounting anyway. 2017-05-23 07:00:42: home.mount: Directory /home to mount over is not empty, mounting anyway.
1. Does 'Disk 1 has 1 Current Pending Sectors'indicate the start of disk failure?
2. Is the rest significant?
This is recent - on disks all of different ages all since April
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAIDar diagnostics
1 is not a lot, but you should certainly keep an eye on that disk.
As for the other issue it's not that important.
You could do
# mount --bind / /mnt # rmdir /mnt/home/*
# umount /mnt
and that should get rid of that message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
hi mdgm
Thanks but:
mount --bind / /mnt
rmdir: failed to remove '/mnt/home/*': No such file or directory
though
mount --bind / /mnt
does seem syntactically correct to me???
- Mark as New
- Bookmark
- Subscribe
- Permalink
if you do ls /mnt do you see the home folder?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi StephenB,
After
mount --bind / /mnt
I see home
drwxr-xr-x 1 root root 0 May 25 07:54 home lrwxrwxrwx 1 root root 5 Sep 25 2015 homes -> /home
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the Ultra:
# ls -ahl /home
total 16K
drwxr-xr-x 1 admin admin 0 Oct 3 2015 .
drwxr-xr-x 1 root root 242 May 28 08:31 ..
root@NASUltra:/home#
On the Pro:
# ls -ahl /home
total 16K
drwxr-xr-x 1 admin admin 20 Sep 18 2015 .
drwxr-xr-x 1 root root 276 May 30 08:08 ..
drwx------ 1 admin admin 0 May 27 10:32 admin
drwx------ 1 david users 0 Oct 9 2015 david
root@NASPro:/home#
I haven't woken the 314 up yet - doing some re-cabling
- Mark as New
- Bookmark
- Subscribe
- Permalink
The idea is to do ls -alh /mnt/home
/home is a mount point for /data/home. Once the system is booted, when you browse that, you are really looking at the data volume.
Your error messages are saying that the mount point itself has files in it - and it shouldn't. Remounting / as /mnt allows you to see what's in the mount point, instead of the data volume. But that only works if you look in /mnt/home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apologies StephenB,
Carelessness - worse, I know! (Dumb...)
root@NASUltra:~# ls -alh /mnt/home
total 16K
drwxr-xr-x 1 root root 0 May 25 07:54 .
root@NASUltra:~#
# mount --bind / /mnt root@NASPro:~# ls -alh /mnt/home total 16K drwxr-xr-x 1 root root 0 May 25 07:52 . drwxr-xr-x 1 root root 276 May 30 08:08 .. root@NASPro:~#
# mount --bind / /mnt root@NAS314:~# ls -alh /mnt/home total 16K drwxr-xr-x 1 root root 0 May 11 15:55 . drwxr-xr-x 1 root root 228 May 28 08:32 .. root@NAS314:~#
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've done worse, and I suspect most others here have
Based on your latest post, it looks to me like either
- the original issue is now resolved
- there is a bug in the diagnostic
You might try re-running it, and see if it is still reported.
