× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
RN102: cannot enable Time Machine without volume
Kocourvbotach
Hello,
I have problem with my ReadyNAS RN102 and Time Machine. When I want to enable it, this error appears:
Cannot enable Time Machine without volume
Code: 7062030001.
I have two HDD WD RED 3 TB inside, both are as JBOD and fully functional.
Firmware 6.1.5
Time Machine were working like a charm before I replaced both HDDs. First I moved data from second HDD to the first one. Then I
replaced second HDD and moved data to it from the first HDD. Then I replaced first drive, that should serve for Time Machine
and backup some important folders from the second drive. But now I'am not able to start Time Machine.
Any ideas? I have tried turn on and off all services, repair permissions and so on without success. I know that factory reset should
solve this problem, but I don't want to copy 1,5 TB of datas to external drive...
Thank you!
Message 1 of 8
Guru
Re: RN102: cannot enable Time Machine without volume
Is one of the volumes named data?
I don't use TM, but there are some apps that assume the default volume name.
Message 2 of 8
Kocourvbotach
Hello,
I renamed one of the disks to the "data" but didn't help. :?
Message 3 of 8
adhigadu
hi I am also having the same issue.. Please advise if anyone managed to solve it.. thanks.. :roll:
Message 4 of 8
hockey99
Me too! I am using RAID 6. Are you?
Message 5 of 8
xeltros
Apprentice
Did you try to switch it off and on again ? Maybe it just needs to detect the new volume and recreate a new folder.
Backup is crucial : Learn more here
Message 6 of 8
theluke79
Hi, how did you manage to rename the volumes on rn102?
Message 7 of 8
mdgm-ntgr
NETGEAR Employee Retired
Renaming a volume is not something we would support. Are you also having the issue with Time Machine mentioned above? What version of ReadyNAS OS are you running?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3122 views
  • 0 kudos
  • 7 in conversation
Announcements
