× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN102 v6.10.4 Failed to fetch libc-dev-bin libc6-dev libsqlite3-dev
giofesta
Follower
hi,
as I wrote in the object I can't download the libraries
the log follows:
apt-get install -y libsqlite3-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
Suggested packages:
glibc-doc manpages-dev sqlite3-doc
Recommended packages:
manpages-dev
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,723 kB of archives.
After this operation, 11.1 MB of additional disk space will be used.
Err:1 https://apt.readynas.com/packages/readynasos 6.10.4/main armel libc-dev-bin armel 2.19-18+deb8u10.netgear1
403 Forbidden
Err:2 https://apt.readynas.com/packages/readynasos 6.10.4/main armel libc6-dev armel 2.19-18+deb8u10.netgear1
403 Forbidden
Err:3 https://apt.readynas.com/packages/readynasos 6.10.4/main armel libsqlite3-dev armel 3.25.2-0.netgear1
403 Forbidden
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.4/main/pool/g/glibc/libc-dev-bin_2.19-18+deb... 403 Forbidden
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.4/main/pool/g/glibc/libc6-dev_2.19-18+deb8u1... 403 Forbidden
E: Failed to fetch https://apt.readynas.com/packages/readynasos/dists/6.10.4/main/pool/s/sqlite3/libsqlite3-dev_3.25.2-... 403 Forbidden
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I have already tried with:
apt-get update
apt-get upgrade
these commands do not give errors and do not solve the problem
is there any solution?
tnx
Message 1 of 2
Guru
Re: RN102 v6.10.4 Failed to fetch libc-dev-bin libc6-dev libsqlite3-dev
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 995 views
  • 0 kudos
  • 2 in conversation
Announcements
