× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RN10200 - Not showing Admin Web UI after Factory Reset
TonyT3ch
I have a RN10200 and was doing a factory reset on the device and the Admin Web UI is not responding. The device is pingable and I can see it in the RAIDar App but the front end ui doesn't load.
Model: RN10200|ReadyNAS 100 Series 2- Bay (Diskless)
Message 1 of 10
Guru
Re: RN10200 - Not showing Admin Web UI after Factory Reset
What drives are you using?
How long has it been non-responsive?
Message 2 of 10
TonyT3ch
I have 2 - 1TB Drives and after performing a factory reset the Admin Web UI stopped working. We tried factory resetting it for a second time but encountered the same results. This has been happening since yesterday, we can ping and the device is visible using the RAIDar APP.
Message 3 of 10
Guru
What manufacturer/model?
Can you download the log zip with RAIDar?
Can you access the shares with File Explorer (or Finder) after the web UI stops working?  Or does that fail also?
Message 4 of 10
TonyT3ch
 Netgear RN10221D-100NAS
How can do I do this?
It was factory reset, so no share have been configured.
Message 5 of 10
Guru
Default shares should still be there (assuming the volume was created)
Message 6 of 10
TonyT3ch
That option is not avalible when I open RAIDar.
Message 7 of 10
Guru
That's because the RN102 is saying there are no disks installed in the NAS.  Possibly they failed.
Message 8 of 10
TonyT3ch
How would this prevent access to the Admin UI?
Message 9 of 10
Guru
The OS and application software are on the disks, and the NAS boots from the disks.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1227 views
  • 0 kudos
  • 2 in conversation
Announcements
