- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN104 Stuck at "Booting..."
- Mark as New
- Bookmark
- Subscribe
- Permalink
My old faithful RN104 running f/w 6.10.9 has encountered a problem which I need some help with:
Initially, it sat say "Booting..." indefinitely (no percentage bar appears). All 4 drive lights are on, the "Act" light is on continuously and the "Power" light is flashing.
I could SSH into it, and discovered that I could make any changes to any files as it came up with "no free space" errors. df -h showed plenty of disk space available however.
Tried to do a firmware reset via USB, but it asked me to Telnet into it for debug and wouldn't accept the root password I'd previously set and now I can't SSH to it any more.
So now I'm stuck...what should I try now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN104 Stuck at "Booting..."
Can you log into the web ui?
If you can, then download the full log zip file and look in there for clues.
Generally you need to use btrfs commands to determine the actual free disk space on the volume.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I can't access it at all now...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@daKlone wrote:
Hmm, not that I recall, no.
Start by booting the NAS into tech support mode using the boot menu.
Instructions are on pages 28-29 here:
Next you will need to access the NAS using Telnet. If you are using a windows PC, I suggest you use the Putty client for that.
When you connect to the NAS, log in as root. The password is infr8ntdebug.
After that see if you get any errors when you run this command
rnutil chroot
That starts RAID, and attempt to chroot to the OS stored on the disks. That might fail in your case (depending on what went wrong with your USB recovery attempt).
Other commands to mount the data volume manually are possible, but they depend on your expansion history. If rnutil chroot works, try entering
lsblk
and then post the output here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
"chroot: can't change root directory to '/sysroot': No such file or directory"
Tried the 'OS Reinstall' option too, which seemed to do something but resulted in no change.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried again...didn't realise that the 'rnutil chroot' had worked as there was no "root@" prompt initially...but it looks like it did:
- Mark as New
- Bookmark
- Subscribe
- Permalink
It looks like the volume has never been expanded
You can try to mount the data volume with
mdadm --assemble --really-force /dev/md127 /dev/sda3 /dev/sdb3 /dev/sdc3 /dev/sdd3
btrfs device scan
mount /dev/md127 /data
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interestingly, it reported that /dev/sda3 /dev/sdb3 /dev/sdc3 and /dev/sdd3 were busy and skipped, but was still able to mount the data volume.
So I now have access to the data volume 😁
What's next in terms of diagnosing the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have news!
Doing a bit of digging, I managed to get the device to boot by unplugging the network while it was booting. I can now get to the web admin page and log-in via SSH.
Logging-in via SSH I notice that systemd-journal and rsyslogd are using 55% and 42% CPU respectively, making everything very sluggish.
I also noticed that /var/log/daemon.log and /var/log/syslog are expanding at a phenomenal rate, both reaching 100M+ in the space of a couple of minutes!
'tail -f /var/log/syslog' gives:
Which seems to suggest that 'minidlnad' is throwing continuous errors due to not finding some files, which is filling the log files and bogging down the CPU.
Any suggestions as to what to do next?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I turned off DLNA but Plex had disappeared from the 'Apps' section so I deleted it manually (just in case)...and calm has been restored!
Just to complete the story, I forgot to mention that as soon as I was able to log-in to the web GUI I re-loaded the firmware again (v6.10.9).
It's a bit disconcerting that I still don't know what exactly went wrong, but I'm re-building it bit-by-bit to see if it goes wrong again at any point.
Thank you Stephen B, as always, ready and able to assist! 😎
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm glad I could help.
I'm not sure exactly what went wrong either, but the plex media library (in .apps) appeared to have been partially deleted.
