- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN2120 6.5.0 Very slow read after upgrade. Write is still ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reading performance slow but write performance is good. I'm using a movie of 4GB which is written to the NAS in 30 seconds. When trying to copy it back to the PC it takes 10 hours.
I get the same poor reading performance on two different PC's and through two different switches. I've also tested to copy the file between the PC's through both swithes and the results are the same. Thus, copying the file works well in all cases except when it is read from the NAS.
No snapshots or cloud services enabled.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN2120 6.5.0 Very slow read after upgrade. Write is still ok.
Do you have jumbo frames enabled on the NAS? Is so try turning them off.
Also, are you using teaming?
You might want to look at the packet stats on the NAS nic - you can find them in the downloaded log zip.
- Mark as New
- Bookmark
- Subscribe
- Permalink
MTU is 1500. Teaming is not used.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this the packet stats you are looking for?
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:15329153 errors:0 dropped:98 overruns:0 frame:0
TX packets:4592925 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:21768812970 (20.2 GiB) TX bytes:5584682374 (5.2 GiB)
Interrupt:26
RX packets:77352 errors:0 dropped:98 overruns:0 frame:0
TX packets:16553 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:17346084 (16.5 MiB) TX bytes:3115963 (2.9 MiB)
Interrupt:27
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using Explorer is very slow but downloading the same file using HTTP works ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interrupt:26
Interrupt:27
Yes. There don'e seem to be any issues here
- Mark as New
- Bookmark
- Subscribe
- Permalink
What OS is running on the two PCs? If you have A/V or internet security software running on them, have you tried disabling it?
If you are using Windows, could you try a test with NasTester (http://www.808.dk/?code-csharp-nas-performance)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Windows 7. No change when A/V and Firewall is disabled. Also, performance is ok between the computers when accessing a share on one of them from the other. The issue is only when reading from the NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 100MB file write on \\NAS2\Movies once...
Average (W): 11,66 MB/sec
Running a 100MB file read on \\NAS2\Movies once...
Average (R): 0,30 MB/sec
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is helpful. You have a 100 mbit (fast ethernet) connection at the PC? If so, is the NAS connected with gigabit?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Gigabit for the NAS. Tried different connections for the PC - Gigabit and WiFi. Two different switches tested. Note that read is ok over HTTP but not SMB.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did see that the read worked ok with http.
The 11.6 MB/sec write speed suggests that you have a 100 mbit connection somewhere along the path. So I was wondering about queue overrun in whatever switch is doing the downspeed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue though when the PC is directely connected to the same switch as the NAS and both the PC and the NAS is using Gigabit. Write was faster than over WiFi but Read still very slow.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since this happens on the wired connection, troubleshooting it on wifi will only make things harder to isolate.
The next step is a direct-connect test - with the PC ethernet directly connected to the NAS (bypassing the switch). You do need to set up temporary static IP addresses on both devices to get this to work, and also access the NAS with it's IP address instead of its name.
Also, have you tried this on a second PC? Is IPv6 enabled on the NAS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
After disabling IPv6 read is ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully Netgear will fix that. But at least it "solves" your issue for now.
