× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
RR2304 - System volume root is 91%.
4x2TB NAS with current OS 6.10.2 reports the same warning message on 91% usage as many other users were facing already. According to the info here I have
- turned on SSH Service
- turned off AntiVirus
- logged on with Windows 10 SSH client and changed into directory /var/lib/clamav#
My questions:
1. It shows 267 MB usage and that makes the 91% usage. What files do I have to delete?
2. If I mess up the system I need to restart with factory defaults. Does it mean my setting are gone or do I loose all data on the NAS?
Doing a backup is easy spoken but 4 TB not just into the pocket.
Message 1 of 14
Accepted Solutions
Re: RR2304 - System volume root is 91%.
Finally I could free the OS partition, no more warning messages, thanks for all the help.
I add a small summary of my steps for others that may have a similar problem.
1. Preparations in NAS settings
a. Activate SSH Service with password: System > Settings > Services
b. Turn off AntiVirus
2. SSH login (Windows 10)
ssh root@<nas-ip-address>
Password: NAS Admin password
3. File search
a. Search for any large files >200MB: find /var -type f -size +200M
b. Look into Antivitus definition directory for any temp files: cd /var/lib/clamav
ls -lsh
c. Look into media/USB_HDD_1 (that is my 8TB USB connected HD) folders for any files
Result 3a-c: no large files, no temps, nothing peculiar in USB_...
Some threads can be found here where users had to delete the /clamav tmp files, not in this case.
4. Mount the root partition as mnt to eliminate directories from listing that actually point to the data partition
a. mount --bind / /mnt
b. ls -lsh -> found many chunk-0000x files in the root directory (StephenB telling that this is from PLEX transcoding)
c. Delete files: rm /chunk-00*
Another ls -lsh: all chunk deleted and reduced partition usage from 3,5G to 1G
d. cd //
unmount /mnt
e. Turn on AntiVirus in NAS settings
Message 14 of 14
All Replies
Retired_Member
Not applicable
You can search large file in root OS partition,the command as below:
find /var -type f -size +500M
Message 2 of 14
Guru
FWIW, you've found that your problem isn't caused by the ClamAV antivirus service.  It's caused by something else.  @Retired_Member's command should help you find the file(s) that are causing the problem.
Alternatively you could use paid support at my.netgear.com.
A 4 TB USB drive costs about $100 in the US.  Per-incident support from Netgear is about the same cost.  And if you ever need data recovery (and w/o backup you eventually will), you'd be spending $300 or more (recovery software + the drive to put the recovered data on).  More importantly, there's a good chance you won't get your data back.  I get the need to manage expenses, but IMO not investing in backup is false economy.  So maybe think a bit about what data loss would mean, and what your data is worth to you.
You'll have to rebuild the NAS from scratch - so all your settings and data will be gone.
Message 3 of 14
@stephen, thanks for clarification. Fully agree, 100 bucks is nothing compared to loss of data.
I think I got the directory that sucks. I'm transferring surveillance pics and 100M mpgs via ftp and seems that they remain in /var/ftp that has now 266Giga. I think deleting all subfolders will solve the problem but better wait for the USB disk.Smiley Frustrated
I haven't seen any setting in FTP protocol regarding directory or file deletion.
Message 4 of 14
Guru
Be careful here.  /var/ftp is actually a linux mount point.  The on-disk space you are seeing here is really on the data volume (/var/ftp mounts the shares that have ftp enabled for the FTP server).  It's not the cause of your full OS partition (which is only 4 GB in size btw).
Try remounting the OS partition as /mnt - that will take the mount points out of the equation and make the OS partition easier to search.
# mount --bind / /mnt
Sometimes files end up "underneath" mount points - particularly if you use USB backup jobs.  So after doing the mount, look in /mnt/media first and make sure all the folders in there (USB_HDD_1, etc) are empty.
When done, you unmount with
# cd //
# umount /mnt
The umount won't work if you are in the /mnt folder (what's why the cd // command is there).
Message 5 of 14
Ok, create an alternate view on the root partition called mnt and search for files that maybe underneath the radar. I mean, 91% of 4GB can't just hide somewhere.
Let me wait for the USB drive this week and once the backup is done I will come back and report.
Most the other system usage stories here had an issue with the ClamAV that seems to be not the case here.
Message 6 of 14
Btw. that command doesn't find anything, only below 100M you get results.
Message 7 of 14
Guru
Of course it depends on what the underlying problem is.  Often it's one or two oversize files - in which case @Retired_Member's command is great.  In other cases, it's filled with a bunch of smaller files.  Did you look in /mnt/media at the USB folders (after using the mount command I posted earlier)?
Message 8 of 14
When trying to save on USB disk I had a system crash with subsequent Hardware replacement. That's why I didn't responde for a while. Thank Good I could recover all data except some movies. Alfer having the new system reallocated to Insight I got 87% volume usage.
The main reason is my Plex application. Out of 1,87GB total I have 800 MB in /data/apps/plexmediaserver/medialibrary/Plex Media Server/Media and 300MB in ../Metadata.
I could delete the Media Library manually and rebuild it. If that ends in the same result, can't I just source this data out of the root file? Or is that path hard-coded in Plex?
Message 9 of 14
Guru
If you mean put it in the OS partition, then that would be a very bad idea.
/data is the data volume - so something is wrong with your units.  Did you mean 1.87 TB for the total size?  If so, why is ~1 GB concerning?
Message 10 of 14
Ok, I'm actually on the wrong path with that.
I did the mounting btw. as mnt, it shows me 3,5G, which is 87% of 4.
Changed into media trying to catch something "underneath"  but.... unsure
Message 11 of 14
I can see a lot of chunk-0000x files all from the same date.
Message 12 of 14
Guru
Those are generally from plex (aborted transcoding).  So just delete all of those.
Message 13 of 14
3. File search
ls -lsh
d. cd //
unmount /mnt
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2384 views
  • 1 kudo
  • 3 in conversation
Announcements
