- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Raid1 and ext4 filesystem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Netgear RNDX4250. Version.4.2.27. i have 2x2 tb disk. And i want to create raid1 filesystem should be ext4 . How can i create?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Raid1 and ext4 filesystem
If you are starting fresh, just put the two (unformatted) drives into the NAS and power it up. The NAS will use xraid, but with two disks that is standard RAID-1.
If you aren't starting fresh, you need to give us more information (whether you are using xraid or flexraid, what's in the NAS now, etc).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi again,
Im using flexraid raid1 on netgear now. I think flexraid not supported ext4. Right? I did not know what xraid.
How can i create xraid raid 1 ext4?
This link my raid configuration
http://s8.postimg.org/lq2zeiw7p/raid.jpg
Thanks for your answer
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looks to me like you are already creating it.
Your NAS always uses ext for the file system. Whatever RAID you chose, you will still be using ext.
ext is not a network protocol, so over the network, you access shares using CIFS/SMB, AFP or NFS. But the file system itself is ext.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes i know. Whats the ex4. My customer data folder size more than 32,000 on the netgear. ext3 file system not support up to 32,000 folders. My customer number of folders more than 40,000. That's why I need create ext4 filesystem raid. if i have flexraid and raid1; my customer can not create any folder on the netgear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My pro is running 4.2.28, but the file system was created some years ago with older firmware. It uses xraid, and the C data volume is definitely ext4. You can check yourself with ssh.
PRO:~# blkid
/dev/md0: UUID="xxx" TYPE="ext3"
/dev/md1: UUID="xxx" TYPE="swap"
/dev/md2: UUID="xxx" TYPE="lvm2pv"
/dev/md3: UUID="xxx" TYPE="lvm2pv"
/dev/mapper/c-c: UUID="xxx" TYPE="ext4"
I "only" have 26,000 folders though, so I can't confirm if > 32000 works or not.
Your limit might not be ext4, it might be something else. Are all these folders in the same share? Is the sharing protocol SMB or something else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi again Stephan,
No I dont using smb. Im using only network share folder. My customer is a hospital. And they are backup patient dcom files on netgear. Each patient panaromic files sending to backup folder. Everyday 400 patient files and folders sending to netgear. BackUp total of 3 years on the device.
1-) I will destroy volume after i will create x-raid2 new volume. Is there a point I need to pay attention?
2-) I can change using ssh flexraid1 filesystem ext3 to ext4?
Thanks for your all answers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think you are confused here. Network shares always have one or more sharing protocols configured. The NAS lets you share with CIFS, NFS, FTP, HTTP, and RSYNC. You have to be using one of those - otherwise you are not sharing. CIFS is the same as SMB and is the most common.
You can see what protocols are enabled for each share using frontview - just click on "shares" and you will see a table. Entries not enabled are grayed out.
I think you should use ssh to see what the current file system is before you go any further. You can use the blkid command I posted above.
I believe you already have ext4.
FWIW, another approach (requiring flexraid) is to add two more drives to the NAS and create a second RAID-1 array. Then split the patient files across the two volumes. You'd need at least two shares to do that (one on each volume).
