× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 104 Inaccessible - ReadyNAS Admin Page is Offline
haigha
ReadyNAS 104, running System 6.10.7, with 4 x 2TB drives.
Rebooted after NAS became unresponsive, but NAS is still inaccessible on local network via browser or via ReadyCloud.
Network Activity light is blinking, four drive LEDs are constantly on, and the NAS fan comes on intermittently for cooling.
The driver has been running without problem for several years and no changes have been made to the network.
Any assistance/suggestions very welcome.
Message 1 of 44
Accepted Solutions
haigha
Re: ReadyNAS 104 Inaccessible - ReadyNAS Admin Page is Offline
Managed to back up my essential files, removed the failing drive and replaced with another, let the RAID rebuild then installed the most recent firmware update. Everything is now much more responsive.
Thanks for all your assistance.
Message 44 of 44
All Replies
Marc_V
NETGEAR Employee Retired
@haigha
Have you used RAIDar to detect the NAS? If not, RAIDar can be acquired here. If there is network connection the NAS should be detected by RAIDar and provide status information and download logs if possible.
You may have a full OS partition or full data volume making the NAS inaccessible.
Message 2 of 44
haigha
I use a Mac, running Monterey 12.3.1, so I had to install java before installing RAIDar.
RAIDar finds my NAS on my local network but when I try to download logs, it prompts for a password. I enter my admin password and it just hangs. I've forced RAIDar to quit and restarted, only to get hung again on entering password. I even tried the NetGear default password with the same effect. RAIDar does show all four drives in good order.
Message 3 of 44
Marc_V
@haigha
Have you tried using a different computer or browser when trying to access the admin page? even when using the IP address?
Message 4 of 44
haigha
Yes, tried an older Mac using Sierra, and my iPhone.
Now and again, the web page in a browser window will ask for my admin password, and it will try to load the admin page, but it always ends up displaying the same error: ReadyNAS Admin Page is offline.
Message 5 of 44
Marc_V
If you still can't get the logs. It will be best to contact ReadyNAS Support via E-mail readynassupport@netgear.com.
HTH
Message 6 of 44
haigha
I tried several reboots, and eventually the NAS showed up in RAIDar after leaving overnight.
I was able to enter my password, but it hung again when I tried to access logs.
I tried a reboot and it hung at 99% after leaving overnight.
When I press the power button, I get what looks to be an error message <fvapp-transmissio>.
I'm guessing the transmission application may be causing some kind of problem, but I have no idea how I might remove the app if I can't mount the NAS.
Message 7 of 44
haigha
Apologies, but I had to put this issue to one side for a while.
I just rebooted the NAS using the reset procedure and chose OS reinstall from the menu.
The NAS booted slowly, sitting at 92% for a while, but even after fully booting the NAS still does not show up on my network, even using RAIDar.
Message 8 of 44
Guru
What IP address are you seeing on the front panel?
Is this IP address in your home network's subnet?
Message 9 of 44
haigha
https://10.0.0.7/admin/
Yes, home network.
Strangely, I have Transmission and qBitorrent installed on the NAS and web interfaces for both are viewable in my browser.
Message 10 of 44
Guru
Yes, home network.
So to clarify - the web ui is offline, but app web interfaces work.
I am thinking that SMB access also works - is that the case?
Message 11 of 44
haigha
Yes, app web interface works, but web ui is offline.
I attempted a direct ethernet connection using 192.192.168.100 with subnet 255.255.255.0 on my Mac and
the NAS indicated it was connected to169.254.34.224 after a reboot.
My browser indicated it couldn't find the NAS Z@ 169.254.34.224
Message 12 of 44
Guru
Is finder able to access the shares?
A waste of energy, as the IP configuration is clearly ok.  If it were wrong, the app web interfaces would also fail.
An OS reinstall might help.
Message 13 of 44
haigha
An OS re-install might help
I did do a re-install, and it reset to the NAS to the default password.
I can do another if you think it might help.
Unfortunately, not.
I did manage to get a listing of the shares using ReadyCLOUD browser interface, but couldn't access anything beyond the listings--the request times out.
ReadyCLOUD shows a firmware update is available.
Message 14 of 44
Guru
Are you seeing any issues on the NAS front panel?
Unfortunately, not.
Unfortunately, not a good sign.
Does it look like the apps can access the data volume?
Do you have access to a Windows PC?  Or just a Mac? (There are a couple things I could suggest trying with Windows, but I am not a Mac user, so I don't know the steps there).
It's a long shot if you've already done one, but it is easy to do, so worth a try.
It does reset the NAS admin password (and a couple of other settings), as well as doing a partial installation.
Message 15 of 44
haigha
I'll give this another shot.
How about a firmware upgrade if the OS re-install doesn't help?
As a last resort, I'd like to transfer the disks, which seem to be okay, to another NAS and spin them up there.
Is this possible?
Message 16 of 44
Guru
Is this possible?
Actually I think the issue is the OS/ReadyNAS application - which is on the disks.
If you have a spare disk, you can test this by
  • powering down
  • remove current disks (labeling by slot)
  • power up, and install to the spare disk
If that works, then the problem isn't the NAS chassis.
A USB recovery is another possbility you could try.
Message 17 of 44
haigha
Are there instructions for a USB recovery?
I may have a spare disk, and if I can find one, I'll try installing the OS to that disk.
Message 18 of 44
Guru
https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
Be careful to follow the instructions for ARM.  If you have a flash or USB drive that has an activity light, it is good to use it.
Note this updates the flash memory, not the OS running on the drives.  But since you are running 6.10.7, then if you install 6.10.8 on the recovery disk, and that will end up updating the flash memory first, and then the OS on the disks will be updated when you reboot the system.
Message 19 of 44
haigha
Okay, I prepared a USB drive and downloaded <ReadyNASOS-6.10.8-arm.dmg> but I can't get the image to mount--seems others are having dmg-mount issues. Trying to resolve this to get access to latest firmware.
Is there any other way to access the firmware other than .dmg?
Message 20 of 44
haigha
I've tried to mount the ReadyNASOS-6.10.8-arm.img file on three different Macs--all of them fail to mount the .img file.
Any chance the original .img file is corrupt?
I've also downloaded the original file 3 times to ensure it wasn't a corrupt download.
Message 21 of 44
Guru
dmg????  The extension is img.
Why are you trying to mount it?  There's nothing in the instructions that say to do that.  You just move the .img file into the appropriate folder.
Message 22 of 44
haigha
Ah! - gotcha
Message 23 of 44
haigha
Using the rear reset button, I started NAS into Boot Menu, but there's no option for USB recovery.
I read somewhere (can't remember now) that to boot some rack NASs into USB recovery, the reset button is the front backup button.
I'm guessing I should use the front reset button to access the USB recovery mode in the menu?
Message 24 of 44
haigha
Apologies if this is a double post--I posted earlier but I'm not seeing it...
These are the files I've copied to the USB drive; is this correct?
Message 25 of 44
Top Contributors
Discussion stats
  • 43 replies
  • 3563 views
  • 0 kudos
  • 4 in conversation
Announcements
