× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 2304 6.10.4 Firmware has broken Volume data Rsynch backups
OGB
I still have this issue on 6.10.5 hotfix 1...does anyone know if this has been fixed yet?
Thanks.
Message 1 of 5
Accepted Solutions
Guru
Re: ReadyNAS 2304 6.10.4 Firmware has broken Volume data Rsynch backups
@OGB wrote:
I have noticed that case matters when creating exclusion rules so how would snapshots be written?
See this old post:  https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Volume-backup-via-rsync-exclusions-...
One comment on the post (which I also added the original thread):
@dmuller wrote:
  • /data/.apps/ (Maybe apps store data here? Anyone know?)
This is where the apps are installed (/apps is a mount point for this folder).
Message 4 of 5
All Replies
Guru
Actually it turned out to be an undocumented setting change.  Go into the "advanced" page for the backup settings and make sure "Multiple File Systems" is checked for the volume backup job.
Note there is a warning in the help (the ? next to the setting) saying that you need an exclude rule in the backup job if you have snapshots on the volume (otherwise the snapshots would be included, which would greatly multiply the amount of space needed for the backup).
Message 2 of 5
OGB
Thank you.
Message 3 of 5
Guru
Message 4 of 5
OGB
Thanks for this info ....much appreciated!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1506 views
  • 2 kudos
  • 2 in conversation
Announcements
