- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS 314 - fan with
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear community,
from a colleague of mine I got a ReadyNAS 314. Due to the fact that I am already using a 214er I was quite happy because this device seems to be quite new. It was a quite lucky situation for me because I needed an additional NAS very fast and so I commissioned it as soon as possible. Nearly everything is perfect with this device...
My problem: This 314 respectviely its fan jangles my nerves. Every 3 or 4 seconds there is a clicking noise coming from the fan and additionally this fan sounds like getting faster and lower also every 3 or 4 seconds (sounds like there is a difference in speed of some turns per minute only and not such a big difference). My question: where can I (from Germany) get a spare fan from for this device? Or (espacially the noise of getting faster and slower) is this a known problem and how can it be solved?
Kind regards
Sebastian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS 314 - fan with
Hi @vollprofi1
Are you certain that the noise coming from the fan or the disk? have you checked the temperature under System>Performance? Most likely the fan adjusting its speed is due to the temperature reading, so the NAS should be located in a well-ventilated place.
If everything seems to be normal, perhaps we can check the logs to see what's causing the problem.
If you still have a warranty I would also suggest contacting NETGEAR Support so they can assist you in case the chassis needs replacement.
Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @vollprofi1
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
