× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS DUO V1 - 2 volumes
speederd
I have a ReadyNAS DUO v1 with two 2TB hard drivee and for the life of me I cannot get it configured as 2 volumes (2TB for each volumes). Here is what I have done...
1. Factory reset.
2. Select Setup in RAIDar and selected Flex-Raid 0.
3. Once it reboot I go to the web interface and I see my two hard drives. If I select both and create a volume and select RAID 0, it spans the 2 HDD to one volume with a total capacity of 4TB. If I select RAID 1, I get a total capacity of 2TB with redundancy. If I select only one HDD and create a RAID 0, once that is done, I cannot select the 2nd HD, see the reference screen shot.
I need help figuring this out, thanks!
Message 1 of 3
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS DUO V1 - 2 volumes
Go to the "Add Volume" Tab. See it up the top to the right of "Volume C" ("Volume C" is highlighted with a purple background). Then you can add a RAID-0 volume using the second disk.
Welcome to the forum!
Message 2 of 3
speederd
THANK-YOU THANK-YOU mdgm, I feel like idiot for missing that.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1005 views
  • 0 kudos
  • 2 in conversation
Announcements
