- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Diagnostic error
- Mark as New
- Bookmark
- Subscribe
- Permalink
OS 6.5.1
2 x WD RED 1TB drives
Hi
Just did a diagnostics on my Ultra - errors were shown so I did a defrag. The result was:
Successfully completed diagnostics
System
Logs
2016-09-12 09:57:39: journalctl[4522]: segfault at 7f326292ee68 ip 00007f326a15bf71 sp 00007fff0d248100 error 4 in libsystemd-journal.so.0.0.3[7f326a159000+11000]
2016-09-02 09:21:17: EXT4-fs error (device sdc1): ext4_put_super:789: Couldn't clean up the journal
2016-09-02 09:21:16: EXT4-fs error (device sdc1): ext4_journal_check_start:56: Detected aborted journal
2016-09-02 09:17:57: EXT4-fs error (device sdc1): ext4_journal_check_start:56: Detected aborted journal
Is this immininent disk failure?
Many thanks
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Diagnostic error
Can you send me your logs (see the Sending Logs link in my sig)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
sdc is an external disk. Have you run a filesystem check on that?
Also we have newer firmware. ReadyNAS OS 6.5.2 is now available!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks mdgm,
I'll run a fschk on the backup disk.
Isn't
referring to memory (in the NAS)?
I have the NASUltra 2, NASPro and NAS314. None say an update is available.
I have downloaded the x86_64 update and will install it manually tonight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
From my first post:
Can I remove this from showing every time I do a Diagnostic or is it the NAS itself that has a fault? I don't know what it means.
What can I do to delete the journal?
Ditto.
I have checked my USB connected backup drives (sdc1 ?) and they have no errors.
Many thanks
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think that segfault is a harmless error that you can ignore.
Have you run a read-only filesystem check of the filesystem on the USB disk?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You won't get a segfault error when checking diagnostics on 6.6.0.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi davidr1,
Have you ran the Windows Disk Error Checking tool on your USB drive while it's connected to your PC?
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks for the replies,
I only run Linux (Ubuntu).
Raidar says it is up to date on 6.1, NAS OS is now 6.5.2 (was 6.5.1 on first post)
@mdgm wrote:You won't get a segfault error when checking diagnostics on 6.6.0.
I assume that is OS 6.0 when released?
@mdgm wrote:Have you run a read-only filesystem check of the filesystem on the USB disk?
Ran it through gparted - I'm Linux only.
I'll do it through the command line. Thanks BrianL, but I don't have Windows. Seatools might be an option.
Any ideas if and how I can remove the journals the error messages refer to?
Much appreciate your help.
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi davidr1,
I am not sure how but let me check it with my colleagues and get back to you.
Kind regards,
BrianL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi BrianL,
@BrianL2 wrote:Hi davidr1,
Kind regards,
BrianL
Any luck yet, please?
I ran Diagnostics again today. The results were:
On the ReadyNAS 314 (2x4TB WD Red):
2016-09-28 09:53:26: EXT4-fs error (device sdc1):
ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-09-25 08:44:28: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-09-23 13:42:28: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-09-13 13:06:40: EXT4-fs error (device sdd1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-09-10 14:12:09: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-09-06 14:47:02: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-09-03 13:56:17: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-09-01 12:44:05: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-08-30 13:10:40: EXT4-fs error (device sdd1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-08-24 09:36:51: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-08-16 14:30:47: EXT4-fs error (device sdd1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
2016-08-14 09:49:40: EXT4-fs error (device sdc1): ext4_mb_generate_buddy:757: group 2179, block bitmap and bg descriptor inconsistent: 32254 vs 3021 free clusters
On the Ultra (2x1TB WD Red):
2016-09-12 11:23:04: journalctl[7632]: segfault at 7fcf2d8a9e68 ip 00007fcf35200f71 sp 00007ffd28a192f0 error 4 in libsystemd-journal.so.0.0.3[7fcf351fe000+11000]
On the Pro (2x2TB WD Red):
2016-09-23 07:39:28: EXT4-fs error (device sdc1): ext4_put_super:789: Couldn't clean up the journal
2016-09-23 07:23:24: EXT4-fs error (device sdc1): ext4_read_inode_bitmap:184: comm rsync: Cannot read inode bitmap - block_group = 384, inode_bitmap = 12582928
2016-09-23 07:23:10: EXT4-fs error (device sdc1): ext4_find_entry:1457: inode #2: comm rsync: reading directory lblock 0
Any advice as to what this means would be appreciated - especially if I need to replace any disks.
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you still see this on 6.6.0-RC2?
EXT4 is a Linux filesystem. You could do a read-only filesystem check on the USB disk using e2fsck if you specify the right options. I would suggest using the options to do a read-only check first and check to see the result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi mdgm,
Thanks for your reply.
I'm on 6.5.2. I steer clear of Beta releases as these are in business use. So I haven't tried 6.6.0-RC2.
Are you saying that sdc drives are external? Then in a 4 bay RAID 2 how are the drives designated?
Critically, does any of my post refer to internal NAS drives?
IMHO it would be great if the NAS did not check external devices - and cause fewer heart failures 🙂
Many thanks,
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do realise this forum is busy and I do appreciate the support it gives.
Does my post indicate disk failure in the NAS units?
Many thanks
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lots of errors with your external disk - if it is healthy perhaps it needs reformatting.
Netgear said that the segfault was fixed in 6.6.0. What else are you seeing that is concerning you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Many thanks StephenB.
@StephenB wrote:Lots of errors with your external disk - if it is healthy perhaps it needs reformatting.
Yes, I have run e2fsck on all of them (for the three units I use 12 disks - daily or weekly or monthly backup disks) and 'corrected' the errors.
How do I clear the logs so the next diagnostic does not show the same historical errors ?
I'm on 6.5.2 -6.6.0 isn't released yet is it except in Beta? I need to be sure it is 'safe' before installing betas. Check For Updates says I have the latest.
I think what concerns me most is why does OS 6+ check external backup drives when doing Diagnostics? The results can be confusing (as they were to me) as IMHO checking external backup drives should be the job of the user. My immediate reaction is my NAS disks are failing.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyNAS OS 6.6.0 has been released. It is available as a local update only at this time.
After checking it on 6.6.0 you could post an idea in the Ideas Exchange suggesting that the Diagnostics tool makes it clear which disks are internal and which are external.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks mdgm
And thanks also to StephenB - you guys and others help us so much.
Please know it is really appreciated.
I will update this weekend, check and make the suggestion.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Upgraded 31400, Pro and Ultra to 6.6.0 and ran Diagnostics as requested. Run at 2016-10-01 11:15 approx.
1.
No external drives attached. Diagnostics on Ultra show a segfault though note the date:
2.
Is there any way of preventing historical faults on sdc1 from showing in these reports? Clutter, confusing and annoying 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
The logs do get rotated/truncated automatically after a period of time. Not sure how many lines we keep for the journal, but it is several times the amount of lines we include in the logs zip download.
- Mark as New
- Bookmark
- Subscribe
- Permalink
