Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo admin UI for a USB disk: no filesystem
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-24
06:05 AM
2015-06-24
06:05 AM
It has worked OK for a year now, but suddenly now it says (after a reboot) that no filesystem for a USB disk (GoFlex 2TB).
I have root access to the NAS via ssh, and from there
I see no I/O errors or any other errors regarding to USB or that disk, or any disk. Only problem is that frontview does not "see" it, says "No filesystem". The disk is of course then not published and shared by the NAS.
Has anyone seen this before?
- I can see the disk detected in dmesg output
- I can check the disk with fsck: no errors, clean
- I can mount the disk manually using mount to the assumed mount point /USB/GoFlex
- I can cp the data from the disk to another USB disk in order to save it if the GoFlex indeed is faulty and I will lose it
Message 1 of 7
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-24
08:32 AM
2015-06-24
08:32 AM
Re: ReadyNAS Duo admin UI for a USB disk: no filesystem
Does the disk work fine when connected to a PC?
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-24
09:09 AM
2015-06-24
09:09 AM
Nhellie wrote: Does the disk work fine when connected to a PC?
I have not tested that. My PC is currently in Windows mode, which does not work with it as it is formatted to ext3...
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-24
03:14 PM
2015-06-24
03:14 PM
That is odd.
I would suggest backing up the data on the USB disk as the next step if you have not done so already.
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-24
03:24 PM
2015-06-24
03:24 PM
Well, as the picture I show says I'm backing it up to another USB drive in the NAS.. it is still doing that cp... 2TB in folder backup 😉
After that succeeds, I'm truing to re-format the disk using ext3 from the frontview, but I'm afraid that will fail too. But let us see...
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-24
03:36 PM
2015-06-24
03:36 PM
However. I might be in an "unpredictable and unsupported area" as I did this,
I have NOT edited any config files manually as in shell as root. But what I did: I installed a 4 TB LaCie USB disk to this, and I had to manually partition it to 2 x 2 TB partitions for NAS to recognize is correctly. After that the partitions were visible in fronview as LaCie_1 and LaCie_2. Everything worked fine and the older GoFlex was there too.
But now, something.
But now, something.
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-06-24
03:43 PM
2015-06-24
03:43 PM
The Duo v1 does not support GPT so it is limited to 2TB partitions. Not sure whether what you did would work well or not.
Message 7 of 7
