× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS NV+ Volume Correct?
RichIX
Hi,
I purchased a ReadyNAS NV+ last week I have 4x2TB (WD20EARS) but when I look in the total volume available (see attached picture) its showing only 1846 GB available? Is this correct as I thought it would have been 3692 GB available?
Also whilst I have this post up, I have a WD Live Media Player, and connecting to the NAS box its asking for a password (even though every PC on the network can connect to the box fine without a password) anyone know a solution to why it wont allow access to the WD Live Box?
Thanks,
Rich
Message 1 of 12
Guru
Re: ReadyNAS NV+ Volume Correct?
RichIX wrote:
... but when I look in the total volume available (see attached picture) its showing only 1846 GB available? Is this correct as I thought it would have been 3692 GB available?
It should be about 5526 GB. For some reason you are only using 2 drives.
Perhaps the WD Live is connecting with user= admin ?
Message 2 of 12
RichIX
Yep managed to connect but its saying "NO MEDIA" yet theres hundreds of media in there!?
Anyone know how to fix the issue to get it to use all the drives?
Maybe I need to re-sync the drives?
Message 3 of 12
Guru
Try renaming the "media" share e.g. to "media1" (don't forget to click Apply) then rename it back again.
Message 4 of 12
mdgm-ntgr
NETGEAR Employee Retired
That tip isn't for Sparc.
What version of RAIDiator came on the unit? Did it come with 4.1.8?
Message 5 of 12
RichIX
I cannot remember I think it was 4.1.5 I upgraded to 4.1.8 then installed the 4x drives I have re-calibrated the drives and its still only showing 2 disks in use...
How do I get the unit to detect / use all 4 hard drives?
Rich
Message 6 of 12
RichIX
*I also did a full reset on the NAS unit before installing the drives...
Message 7 of 12
mdgm-ntgr
A factory reset only works with drives in place.
Please try this:
1. Backup all data
2. Do a factory default via System > Update > Factory Default (wipes all data, settings, everything).
This should resolve the problem ASAP. Considering that you haven't loaded much data on the unit yet this is definitely the way to go.
Message 8 of 12
RichIX
Hi mdgm,
I will do this now, I dident copy everything across so its not a problem at the moment, will update you in the next hour to see if its fixed..
Cheers
Rich
Message 9 of 12
mdgm-ntgr
Do be aware a resync will have to take place, but the resync when you do a factory default is quicker than the alternative: two resyncs from adding one disk at a time
Message 10 of 12
RichIX
Thanks mdgm,
Problem has now rectified itself following your instructions, thanks!
I just need to figure out how to get the WD Live Media player to detect the media on the NAS. But I feel I might be better going to the WD Live forum to see if anyone can help me there.
Thanks!
Rich
Message 11 of 12
mdgm-ntgr
There a few different options, I think such as CIFS and ReadyDLNA.
If you choose to use ReadyDLNA install the ReadyDLNA update: http://www.readynas.com/forum/viewtopic.php?f=76&t=27946
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1633 views
  • 0 kudos
  • 3 in conversation
Announcements
