Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Remote Connectivity Issue: Resolved
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-06
10:43 AM
2015-02-06
10:43 AM
For those who have Macs and older ReadyNAS units and have had trouble with ReadyNAS remote not working, I have finally got mine to work.
First I downloaded the latest version on tuntap, then I installed the Beta version of Readycloud desktop client, logging in with the Readynas Remote credentials. You will have to allow incoming connections from the firewall. If you use Little Snitch there will be a bunch. Once successfully logged in you will see "Currently You Have no devices Registered". That is ok. Now start Readynas Remote (keep Readycloud client running), and you should login successfully and be able to see your shares. I hope this helps.
The links for the Beta Mac Readycloud App is:
https://readycloud.netgear.com/client/i ... yCLOUD.pkg
If you need ReadyNAS Remote (Since it is no longer available on the Netgear website) here is the link:
http://www.readynas.com/contributed/mdg ... 1.2.15.pkg
Message 1 of 3
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-06
11:55 AM
2015-02-06
11:55 AM
Re: ReadyNAS Remote Connectivity Issue: Resolved
You were able to run readycloud desktop app along with the readynas remote client?
What's your OS?
What's your OS?
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2015-02-06
01:32 PM
2015-02-06
01:32 PM
I'm running Yosemite 10.10.2. Yes, I was able to run both apps simultaneously, but Readycloud needs to launch first. I think the Readycloud app must have opened up necessary ports/paths/routes that ReadyNas remote did not. I just rebooted, and now Readynas remote works WITHOUT the Readycloud app, so it must have just remembered the settings needed from the previous session that worked. I will be keeping Readycloud installed in case Readynas Remote fails to load again. Who knows maybe just a fresh install of tun tap was all that was needed?
Message 3 of 3
