skim32's avatar
skim32
Tutor
Dec 02, 2011
ReadyNAS Ultra 4 Plus Jumbo Frame Issue
I am having trouble with jumbo frames with my ReadyNAS Ultra 4+. My setup is as follows. Both My Computer and ReadyNAS goes to the TRENDNET S80G. The TRENDNET S80G supports JF up to 9k MTU. So I had JF enabled on the ReadyNAS and my computer and I started a large transfer. However, I was seeing transfer rates of 15MB/s. If I disable JF on the ReadyNAS I get around 70MB/s. What's up with that? I verified that the ReadyNAS does have JF turned on. The MTU size is grayed out however it does read 9000. I also set my computer to 9K MTU size. I have my computer's nic also manually set 1000 FULL and the ReadyNAS shows 1000 Full as well. As a test I tried a direct connection from my computer to the ReadyNAS. And still the same issue. Not sure what to do from here on out. Any help would be appreciated.
I'd also like to mention that it doesn't matter if I leave JF on or off on my NIC. I get 70MB/s as long as JF is disabled on the ReadyNAS. But as soon as I turn on JF on the ReadyNAS. It doesn't matter if JF is on or off on my NIC, i get 15MB/s max. Also doesn't matter if I'm connected to the switch or direct connected. Also. If I transfer from the same PC to another PC on the network with JF enabled and set to 9K MTU. I see great speeds 85MB/s. So it has to be something on the ReadyNAS's side.
System Info:
Windows 7 Pro x64
ReadyNAS Ultra 4 Plus running RAIDiator 4.2.19
4 X 2TB HITACHI Deskstar 5K3000
TRENDNET S80G unmanaged Gig-E switch with 9k MTU JF Support
GA-Z68XP-UD3 Motherboard Onboard NIC (Realtek 8111E)
ProSupport for Business
