- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas 104 -Unble to access admin page and shares
- Mark as New
- Bookmark
- Subscribe
- Permalink
DTUnble to access admin page and shares
Successfully completed diagnostics System
- Disk 1 has 13 Current Pending Sectors
Logs
- 2017-08-19 13:32:26: md/raid:md127: failed to run raid set.
- 2017-08-19 13:23:11: md/raid:md127: failed to run raid set.
- 2017-08-19 12:00:49: md/raid:md127: failed to run raid set.
- 2017-08-19 11:36:06: md/raid:md127: failed to run raid set.
- 2017-08-19 11:08:32: md/raid:md127: failed to run raid set.
- 2017-08-19 10:41:12: md/raid:md127: failed to run raid set.
- 2017-08-19 10:12:13: md/raid:md127: failed to run raid set.
- 2017-08-19 09:12:54: md/raid:md127: failed to run raid set.
- 2017-08-19 09:06:32: md/raid:md127: failed to run raid set.
- 2017-08-18 12:54:06: BTRFS: error (device md127) in btrfs_commit_transaction:2232: errno=-5 IO failure (Error while writing out transaction)
- 2017-08-17 07:51:03: md/raid:md127: raid level 5 active with 2 out of 3 devices, algorithm 2
- 2017-08-16 10:35:45: md/raid:md127: raid level 5 active with 2 out of 3 devices, algorithm 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNas 104 -Unble to access admin page and shares
Looks like you may have the start of a hard drive problem. Do you have a current backup?
What's your drive configuration?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So with one drive failing, you just need to obtain a replacement for drive #1. Secure a back if you haven't done so already.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, if you can't access the shares, then it's not just a matter of popping in a replacement drive.
Do you have a backup of the data?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My bad, I assumed that accessing the logs meant he had some level of access to the data...
- Mark as New
- Bookmark
- Subscribe
- Permalink
No worries 😁 only access is via RAIDar 'log & 'Diagnostic' buttons
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, so let's wait for Stephen to make a suggestion for next steps. At this point, we need to consider every step carefully, since it is x-raid I would assume a replacement drive sorts it out, but I don't have a RN104 and I don't use OS6, so let's be patient for someone that has experience with these.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The safest path is to use paid support (my.netgear.com). Ask about per-incident support, that might be enough to get your raid volume mounted.
Netgear does offer a data recovery service if you need it - though data recovery is quite expensive (no matter who provides it). https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
