- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas Duo V2 - After restart, nothing works
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys,
After restarting my ReadyNas Duo V2, I lost all my acces (SMB, DLNA, SSH, Dashboard).
I perform an OS reinstall by boot menu, but nothing changes.
I tested open ports from my Neywork, only telnet port (23) is open. I tried to connect, but i can't find the credentials...
I don't know what to do.
I think about perform a factory boot, but I don't want to loose my data, and don't have nothing to backup it for the moment.
Someone can help me ?
Thanks
Lucos
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNas Duo V2 - After restart, nothing works
Read this guide and tell us whether this is in fact a v2 or a v1:
http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
Alternatively do you know what firmware was running?
When did you buy the device?
Which lights are on on the nas?
Does raidar see the nas?
Did you receive any messages about disk errors?
You say you have tried ssh access, how did you test ssh access?
What disks are in? One of the things you will need to do is to power down and test the disks using vendor tools on a PC.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi vandermerwe,
Thanks for your answer.
It's a ReadyNas Duo v2 (I verified with the guide you sent me).
The firmware version is RAIDiator-arm-5.3.10 (I found the last System Update Status email, from 2014/12/08).
The power button and Disk 1 led are on.
Raidar don't see the nas.
I didn't recieve any messages about disk errors
For ssh, i made a mistake. It could not work has i desinstall SSH add-on few month ago. But 22 port is not open.
There's just one disk. WD Green - 3,5'' 2000 Go - IntelliPower - 64 Mo - SATA III 6 Gb/s
What do you mean by "test the disks using vendor tools on a PC" ? Test the disk with an external usb hard drive box ? I don't have one at home ...
Lucos
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well it would be better to hook the drive up to an internal SATA port in your PC and test it using WD Data LifeGuard Diagnostics.
- Mark as New
- Bookmark
- Subscribe
- Permalink
While you are testing the disk, could you put another spare disk in the nas and factory default it. This will establish whether the chassis is ok or not.
Remember to not insert or remove the data disk while the nas is on, it must be off.
It is also probably worth cloning the data disk. Do you know how to do this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Lucos,
I just want to share this link below where you can download the Windows version of the Data LifeGuard Diagnostics:
http://support.wdc.com/downloads.aspx?lang=en
DaneA
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hy guys, thanks for your answers.
I tested several way to restore my data, but seems to be lost : the HDD is dead.
- WD Data Life guard was not able to analyze the disk
- HDTunes displayed bad sector from the begining of the disk that HDD Regenerator was not able to fix
- I try to clone the data partition of my disk that seems to be safe, but HD clone was not able to do it.
With a new disk the ReadyNas is now working.
I have been able to find the majority of my datas from differents backups on my PC, external HDD but not all 😞
Now I'll wil keep 2 disks in ReadyNas and will make reguler external backups.
Luc
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Lucos,
I am sorry for that. However, at least you still have majority of your data.
Now I'll wil keep 2 disks in ReadyNas and will make regular external backups.
I am glad that your NAS is working fine using a new disk. Having regular external backups would be good practice. 🙂
DaneA
