MrMarc's avatar
MrMarc
ReadyNas - RAIDiator 4.1.16 - Win10 issues
Hi,
I´ve got a ReadyNas Duo running with the latest firmware RAIDiator 4.16.16. Haven´t have any problem, until  yesterday. I´m unable to access the NAS  on WiFi through Win10 browsing \\NAS och \\192.168... or mapping. "Unable to acces..try do identify". Works fine when i use Boxee or my Android phone
I´ve searched the web and it seems to be a workaround. It seems to have something to do with SMB-versions. "Install SMB Plus on the NAS and then change SMB to SMB1". But how will i´m be able to do that on RAIDiator, when its not possible to install apps? How do i fix this? Must be something Netgear can do to help.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    The NV+ (v1) only supports SMB1. It's the default and only version of SMB supported.
    • MrMarc's avatar
      MrMarc
      Thanks
      So what should i do then if this doenst work? I can ping the nas without any problems. Probably this started with som windows patch last week
      • StephenB's avatar
        What happens if you open CMD on the windows system and enter
        net use * /delete
        net use t: \\nas-ip-address\c /user:admin nas-admin-password
        Be careful on the slash direction and spaces (and use the real ip address and admin password of course).
        This normally will mount the C data volume as driver letter T.
