- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
ReadyNas RND4000 v3 not powering on after power cut
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNas RND4000 v3 not powering on after power cut
199M /var/log/daemon.log
234M /var/log/syslog
Truncating these two will likely make the system bootable, but there is more stuff that needs to be trimmed. So I think we need to look in some other places.
Here's what I have in my OS partition:
208k apps 2.6M bin 144k dev 14M etc 17M frontview 16k initrd 36M lib 16k lost+found 16k mnt 832k opt 16k proc 16k ramfs 208k root 3.2M sbin 16k sys 512k tmp 16k USB 158M usr 67M var
Can you try checking these folders?
for instance, enter du -csh /etc to check /etc. Note any large variations and we can drill down into those folders.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So after emptying those two files using the echo command, I was able to boot the NAS, however disk 3 was showing as 'Dead' in in RAIDar and Frontview. I thought it may not be seated properly after me removing/reseating numerous times during troubleshooting, it so I shutdown normally, took it out and reseated it.
After booting again, it is showing the disk as initialising (Screenshot attached). I'm now worried there could be a genuine issue with the disk but I dont want to shut it down again, so do you think it's best to let it complete?
In hindsight I wish I had run the commands for the other directories. It looks like it is going to take a while to complete initialisation (I assume this means initiatilise the disk and also sync with the RAID?), after which I'll go back into tech mode to check size of the other directories. Should I wait until both the initialisation and further clearing of log files is complete before I attempt any further backups/copies of the data off the NAS? I would like to do this at the earliest but safest opportunity...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Probably best to let it complete.
FWIW, you can also install the ssh add-on - then you could clear the logs while running the NAS normally.
Backing up the files is higher priority than completing the fix on the logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenBI can't thank you enough for your help! The initialisation completed along with the sync, so all disks are showing green. Checked the SMART data for the disk and it's not showing any errors, which is strange.
I've managed to start backing up my data which is a relief.
I've tried to run the command to get a list of the directories and this is attached, any in particular to dig into (if indeed I've run it correctly?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
It looks like you are running ssh (with the NAS booted normally). There are some mount points on the OS partition which sometimes can get in the way of analysis. The way to overcome this is to remount the OS partition on /mnt, and then check /mnt.
mount --bind / /mnt
Once you've done that, let's take a fresh look at total space and see if we still have a problem.
df /mnt -h df /mnt -i
BTW, to undo the mount above, you can enter
cd // umount /mnt
- Mark as New
- Bookmark
- Subscribe
- Permalink
Apologies I forgot to mention that I installed the EnableRootSSH add-on. I've run those commands and attached the output
- Mark as New
- Bookmark
- Subscribe
- Permalink
No problem.
28% utilization is in the typical range. So the system appears to have rotated whatever other logs were oversized.
There's no need to do any more with the OS partition at this point, although I do suggest checking the utilization every now and then for next month or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- 1
- 2
- Next »
