Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas ULTRA 6 Redundancy question
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-13
03:03 PM
2011-12-13
03:03 PM
Hey there, I have a ReadyNAS Ultra 6 with 6 1TB seagate hard drives. I'm currently using X-RAID2 and I'm wondering whether or not my setup is set to single redundancy or dual redundancy? Right now with all 6 1TB drives, I have 4611 GB available for use. I don't see any option under volume settings for dual redundancy later, just:
Configuration: RAID Level X-RAID2, 6 disks
Status: Redundant
Any input would be great. Thanks 🙂
Status: Redundant
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-13
03:08 PM
2011-12-13
03:08 PM
Re: ReadyNas ULTRA 6 Redundancy question
You are using single-redundancy. If you were using dual-redundancy it would say so and you would have a volume capacity <4TB not >4TB with your disks.
As your drive bays are full the only way to migrate to dual-redundancy would be to:
1. Backup all data
2. Verify backup is good
3. Upgrade to latest RAIDiator via System > Update > Remote in Frontview (note if running firmware older than 4.2.16 you will need to update twice, once to 4.2.16 and then to the latest firmware).
4. Do a System > Config Backup
5. Do a factory default (e.g. via System > Update > Factory Default).
6. Since you have 6 disks installed X-RAID2 dual-redundancy should be chosen automatically, but if you wish you can open RAIDar (http://www.readynas.com/downloads), click setup during the 10 minute countdown, and choose X-RAID2 and tick the dual-redundancy option.
7. Restore Config Backup
8. Restore data from backup
Welcome to the forum!
1. Backup all data
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-13
03:19 PM
2011-12-13
03:19 PM
Thought so! Thanks for verifying! 🙂 The ReadyNAS Ultra 6 with 4.2.19 firmware should allow me to use disks >= 3 TB, correct? Also, in the event the ReadyNAS box fails, is it possible to retrieve the data without purchasing another ReadyNAS box given its an X-RAID2 setup?
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-13
03:23 PM
2011-12-13
03:23 PM
marky wrote: Thought so! Thanks for verifying! 🙂 The ReadyNAS Ultra 6 with 4.2.19 firmware should allow me to use disks >= 3 TB, correct?
Yes.
Yes. It would be easiest to use another ReadyNAS box, but any x86 Linux machine should easily be able to be used to recover your data (provided disks are fine).
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-13
03:28 PM
2011-12-13
03:28 PM
Thank you very much! Extremely helpful :):)
Message 5 of 5
