- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas 422 Rsync error
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an issue with two of my existing Backups which i am unable to resolve. The host is a Readynas 422 and the remote nas is also a 422.
The only that has changed recently in my setup is a update to the firmware to 6.9.4 on both devices at the end of December. Since then i have been unable to backup carryout two of my sheduled backups and recieve the follow errors
Backup Job Name: *****
Docs Backup
Backup Job Type: Incremental
Protocol: rsync
Backup Source: [******-PC-Documents]/
Backup Destination: [remote:rsync]/5.69.1.178::*******PCDOCS
Backup Start Time: Wed Jan 09 2019 11:46:34 AM
Backup Finish Time: Wed Jan 09 2019 12:22:26 PM
Backup Status: Fail: Failure during copy.
Help much appreciated
Failed to run rsync, return rc 10
'rsync' command returns rc=10
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readynas 422 Rsync error
You appear to be backing up over the ReadyCloud VPN - is that the case?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No I sync my document files and folders via Readycloud over VPN, the backup is via Rsync.
- Mark as New
- Bookmark
- Subscribe
- Permalink
5.69.1.178 is in the backup entry you posted, and it appears to be a ReadyCloud VPN address. It's hard to be certain, since Netgear is hijacking 5.x.x.x addresses for ReadyCloud (these used to be assigned for experimental use, but were reclaimed by IANA when IPv4 addresses started running out).
Can you confirm that 5.69.1.178 is the correct internet IP address of the destination? It appears to be hosted by skybroadband.com.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes this is the correct IP address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is rather unusual to see a static address and not a ddns name as the backup destination for an off-site NAS. FWIW, rsync over ssh is a more secure backup choice for over-the-internet backups since it is encrypted.
One option is to downgrade back to 6.9.3 and see if the backups start working again.
If all backups going to the remote 422 are failing, I'd also check the port forwarding on the remote system, and make sure that the local NAS IP address hasn't changed.
