× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Readynas Ultra 6 (RNDU6000) After Memory Test and rebooted Error " No Disks Detected"
thekidbass
Tutor
Re: Readynas Ultra 6 (RNDU6000) After Memory Test and rebooted Error " No Disks Detected"
One question I forget ask you previously, is the HDMI port in the back of the unit functional? I've never used it myself. If it is, I can connect to a monitor from there.
Message 26 of 55
Sandshark
Sensei
There is no HDMI port on an Ultra6 or any other legacy NAS.  There is a punch-out into which you can mount the VGA cable, once installed.  Note that a USB video adapter will also not work, in case you were considering that.
Message 27 of 55
thekidbass
Tutor
My mistake about the HDMI port on the Ultra 6. I was thinking about the other NAS. I also have a Readynas RN316, which does have a HDMI port but not sure if it is functional. I never used it. In the photo below of the Ultra 6, do you know what that 4pin connector that's above the USB port is for?
The VGA header you mention that is on the motherboard, is it the one that StephenB circled on the photo I uploaded? (courtesy of another member) I'm still not sure.
The 2nd photo is my array of two Readynas and two extension Chasis (EDA500)
Message 28 of 55
Sandshark
Sensei
That 4-pin connector is a UART port -- essentially RS-232 protocol at 5V levels (3.3V on some other models).  I don't believe it can be used to get into the BIOS, but it can be used to see any error messages during boot.
Yes, the header @StephenB circled is the VGA header.  This is the kind of cable you need: https://www.ebay.com/itm/184609738277 .  Note that I have no knowledge of that particular seller, it just came up when I searched.  Oh, and he's labeled the IDC connector pins wrong in the photo, too.  If you choose another source, be sure you get one with a 16-pin dual-inline (IDC) connector (with one pin possibly blocked, corresponding to the missing pin on the header), as there are other versions around.
Message 29 of 55
thekidbass
Tutor
Thank you for the information. I'll search for another seller. At least now I know what it looks like. LOL
Message 30 of 55
thekidbass
Tutor
I revisited my Netgear Ultra 6 after weeks of re-uploading my media to the RN-316. I removed the two side panels and rechecked the connections again. I found the cause of the Readynas not detecting the hard drives installed. The circuit board from the drive bays was not inserted fully on the connector on the main MOB. When I rebooted the Readynas, the hard drives were now detected and I selected "factory reset". It re-installed the firmware and went into "resync" mode. After completing resync, the front display showed channel #5 "on life support". I then shutdown the NAS and removed the hard drive and connected it to my PC and ran the WD diagnostic software and it scanned the HD and the results failed the S.M.A.R.T. test with error code 7. I ordered a new replacement WD Red Plus HD. But aside from that, while it was originally resyncing, the front display also showed "no network link". Is that because of the failed HD while it was resyncing or is it because of another issue? Never had a problem with the ethernet ports. Any thoughts, ideas or suggestions would be appreciated.Ultra 6 Frt Display.jpg
Message 31 of 55
Guru
Likely another issue.  You could try powering up diskless, and see if RAIDar can find it.
Message 32 of 55
thekidbass
Tutor
I'll try that now. Thank you. I'll post an update.
Message 33 of 55
Sandshark
Sensei
Be sure to try both ports, and also try swapping connectors on the router/switch and the cable.
Message 34 of 55
thekidbass
Tutor
Booting  it "diskless" does not give me the info on the "network link" status, since it does complete the boot process and only displays the message "error: no disks detected. I inserted one HD in bay #1 and rebooted the nas. But it is still displaying "no network link" and "no data volume" since the drive is unformatted.Booting Diskless.jpgWith 1 HD installed-No Network Link.jpg
Message 35 of 55
thekidbass
Tutor
This photo with only one HD in bay #1, unformatted. Still displays "no network linl"20221229_094405.jpg
Message 36 of 55
thekidbass
Tutor
I'll try that now. Thank you. Will post an updated.
Message 37 of 55
thekidbass
Tutor
 I connected the ethernet cable to the other port and rebooted. It did successfully aquire a IP address. After receiving the replacement failed Hard drive later this afternoon, after formating the drives in the RAID I select, I want to upgrade to OS6, following Stephen B's link on another post I saved. Thank you Sandshark and Stephen B for you assistance and expertise.Success IP address displayed.jpg
Message 38 of 55
Guru
Which is why I suggested RAIDar.  It normally will detect the NAS on the network, and also show you the "no disks" status.  So you can check the ethernet status that way (which has the advantage that the OS on the NAS disks is taken out of the equation).
Message 39 of 55
thekidbass
Tutor
I thought that since there was no IP address assigned to the Readynas when I initially booted it, that the RAIDar would not recognize it.
Message 40 of 55
thekidbass
Tutor
 I previously posted that one HD failed . After removing that drive and I factory reset the NAS, prior to re-installing the FW, it scanned the disks. Three more drives showeld disk failure. A total of 4 out of the 6 drives. Granted, 5 out of the 6 WD 3TB Red Plus drives are from 2015. Just found that extremely odd and of course frustrating to say the least.
Message 41 of 55
thekidbass
Tutor
I have currently 3 drives in the Reaynas. After scanning the disks, it didn't give any drive errors until it went into resyncing mode and that's when the 4th drive showed a failure on the RAIDar GUI.
Message 42 of 55
Guru
RAIDar "finds" the NAS using broadcast packets - which can work even if the NAS network interface is misconfigured, or if the NAS doesn't get an IP address from the router.
Message 43 of 55
thekidbass
Tutor
Thank you for that info. I learn something new everyday from the experts, like yourself.
Message 44 of 55
Guru
Part of the puzzle is that often disk drives don't discover anything wrong until you try to read or write the section that has bad sectors.  Since a lot of my files aren't read very often, that can result in not detecting issues until long after the failure.
If you convert your Ultra to run OS-6, you can schedule periodic disks tests which can help uncover such issues earlier.  If you enable ssh, you can also run these tests manually with 4.2.x firmware using smartctl.
With OS 4.2.x, you can schedule RAID scrubs.  The scrub exercises the full disks also, so it can serve as a diagnostic.
You can also schedule file consistency checks - they don't read the full disk, but are worth running.
Message 45 of 55
thekidbass
Tutor
Yes, I just went through the entire settings and this time around I did enable both those two features. Thank you.
Message 46 of 55
thekidbass
Tutor
I created a volume with 3 disks and selected FLEX-RAID Level 0 but when it rebooted and completed the resync mode, it created the volume in FLEX-RAID Level 5. I tried deleting the volume via Front View by clicking on the "delete volume" to add the additional replacement drives that I ordered and create a single volume with the 6 Hard Drives but nothing happens. Screenshot attached. Is there another method to change the FLEX-RAID Level to 0?
Message 47 of 55
thekidbass
Tutor
This is the message I get when I try and delete the Volume.
I don't know how to delete that because I don't have iSCSI enabled.
Message 48 of 55
thekidbass
Tutor
I rebooted the nas and was able to delete the volume. I added the 3 disks again and was able to select FLEX-RAID Level 0. One question I have is, when I receive the 3 additoinal Hard drives and install them, will the volume expand automaticallly or will the NAS have to resync all the drives again?
Message 49 of 55
Guru
Neither. RAID-0 isn't expandable, and has no RAID redundancy.  So there is no syncing.  The only option you'd have is to create a second volume.
Not sure why you didn't just use the default X-RAID, as it is expandable and would have been simpler to set up.
Message 50 of 55
Top Contributors
Discussion stats
  • 54 replies
  • 5227 views
  • 14 kudos
  • 3 in conversation
Announcements
